I have built an Aikido amp (12BH7 output). I use a 555 timer to turn on the fiiments first followed by B+ ~30 sec later, and then connect the power amp after another 5 sec automatically.
Question: Can I short the output of the preamp until I finally connect the power amp (~5 sec with B+ applied)? This helps with the thump, but I don't want to do any damage. |
#2 |
#3 |
Thank you. I'm a yube newbie.
#4 |
All of my Aikido's power up with the filaments and B+ at the same time.
If you allow the line stage to warm up and then turn on the power amp there will be no thud. I have used my Aikido's with both SS amps and tube amps. I have no thud period. There is NO need to power up the filaments and delay the B+ at all. There is not going to be any cathode stripping to worry about so why make it any more complex than necessary. |
#5 |
Cathode stripping..... There is a fraternity that believes that this can happen. But this is usually only a problem in High Power amps.
It is contraversial and I don't want to get into an argument in this guys thread. Valve longetivity can be helped along by slowly applying the heater current. When do your light bulbs blow - when you first turn them on normally. We went overboard on this one but it was only an experiment. Last edited by KatieandDad; 8th April 2012 at 11:34 AM. |
#6 |
Not really trying to argue but is it really necessary to go to the trouble of making the circuit to possibly add a few hours to the life of a $5 tube.
Quote Cathode stripping..... There is a fraternity that believes that this can happen. Given the right circumstances it can happen. But not with the circuit in the Aikido with the plates voltages it runs on. |
#7 |
This is a 9-pin dual mono. I'm using a 2.2 uF output cap and driving two power amps in parallell (about 100K each, and a subwoofer crossover (~75 Kohm)). Recently I disconnected the sub, and the protection circuits on the main amps went off. I hooked the preamp up to a scope and observed some faitly random, but smooth subsonic noise whith rare peaks (~0.1 v, usually around 20 mv). I am currently using PS1 from glassware with a choke. I look at the input to the grid in the PSR circit and I see sharp spikes where the largest swings take place but not following the smoot nature of the noise. Qestions:
1) Is this a power supply issue? 2) should I go to a regulated B+? 3) Have I just used too large of a coupling cap? 4) Should I increase the size of C6 in the PSR leg? 4) Has anyone seen this before? |
| xtant 121m turn-on circuit help please... | AKHeathen | Car Audio | 0 | 2nd February 2012 02:07 AM |
| Turn Off Delay Circuit. | mike49504 | Car Audio | 15 | 30th September 2011 12:57 AM |
| SE Tube Preamp circuit using 6922/6dj8 at low voltage(24volt) needed! anyone? | tone | Tubes / Valves | 7 | 20th February 2010 12:11 AM |
| Tube Distortion/overdrive preamp circuit needed | pjpoes | Instruments and Amps | 17 | 26th October 2008 05:01 PM |
