Help with diagnoses for leak 20 PLEASE
Old 6th April 2012, 03:14 AM   #1
mikemac is offline mikemac  Australia
mikemac's Avatar
Default Help with diagnoses for leak 20 PLEASE
For the last couple of days my leak stereo 20 has been micraphonic,. Noisy when touched. About two hours ago, I gave it a good tap, as u do, to see what was buzzing and now have all the symptoms of a short O/T, low volume in one channel
I have changed valves, checked the O/T checked for shorts etc. there is no visible damage to any components and no problem up or downstream: I checked source and speakers.
There is sound in both channels until it warms up and then one drops out. I have had a beer or two and don't want to check the voltages at present. Any thoughts?
Easter break and no music, not good
"my names Mike Peterson, But most folks call me Bull"
Old 6th April 2012, 08:24 AM   #2
Stefkorn is offline Stefkorn  United Kingdom
Maybe a leaking electrolyte capacitor? No other choice but to measure anode supply voltages. Did you notice excessive heat on the mains transformer? Maybe the anode voltage is getting dragged down by an excessive load such as the cathode resistors of the power tubes. I assume they are correctly biased. Worth checking the negative grid voltage to the power tubes.
Old 6th April 2012, 01:03 PM   #3
DF96 is offline DF96  England
Check DC voltages.
What sort of noise do you get when you touch it? Could be RF oscillation, although why it should suddenly start is unclear.
Old 6th April 2012, 01:42 PM   #4
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Once a transformer goes it is usually gone for good.
If it works for a while I would be looking at caps.
BUT, transformers can work OK if the failed insulation is still keeping the windings apart until they warm up.
You might need to substitute L to R to ascertain if the ouputs transformers are OK.
Old 6th April 2012, 01:58 PM   #5
limono is offline limono  United States
When I've got Leak ST-20 all capacitors (I mean all of them) were leaking DC badly and needed to be replaced. The name leak stands for something like used to say Joe Rosen a vintage audio connoisseur If your's is not updated it's definitely a time for it. Happy Easter!
Old 7th April 2012, 04:42 AM   #6
mikemac's Avatar
All components replaced about twelve months ago. Thanks everyone
Old 7th April 2012, 08:23 AM   #7
richwalters is offline richwalters
richwalters's Avatar
Including valve bases ?
This amp has a pentode front end, check all connections around it, esp earthing.
BTW. I get alot of faults from today's constructors...please don't use pliers holding the resistor body..instant damage as shown in pic..as the protection of films is very minimal. The thicker phenol body of an older carbon resistor could take this, but not todays lot.
richy
Old 7th April 2012, 08:36 AM   #8
consort_ee_um is offline consort_ee_um  United Kingdom
You can get thermal runaway with the Leak 20 see:
my leak stereo 20 exploded this morning
My blog:
Consort3′s Blog
Old 7th April 2012, 09:16 AM   #9
So we may be dealing with a fault introduced then, but which has lain dormant for a while. Dry joint affecting feedback stability?
Help with diagnoses for leak 20 PLEASEHide this!Advertise here!
Leak stereo 20 modification Gudmund Tubes / Valves 64 3rd March 2015 03:04 PM
Father, I abused my Leak S/20 bulgin Tubes / Valves 7 4th June 2007 06:15 PM
Leak Stereo 20 questions Johan Potgieter Tubes / Valves 23 1st May 2006 12:57 AM
Motorboating in leak 20 bronto64 Tubes / Valves 5 13th August 2004 11:49 AM
Mods on leak stereo 20 bronto64 Tubes / Valves 22 26th April 2004 09:27 PM
