diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   SRPP Signal Output Capacitors (http://www.diyaudio.com/forums/tubes-valves/210131-srpp-signal-output-capacitors.html)
ssaliba 4th April 2012 01:04 PM
Hi guys
Am I right to conclude that if the output capacitor say in an SRPP circuit fails on short, I would end up with all the high anode DC voltage on the output port with the consequence of blowing up anything which is connected with this output ?
Looking forward for your feedback
stefan
DF96 4th April 2012 02:12 PM
Yes, you are right. If this worries you you could add protection diodes (e.g. a pair of zeners), but there is a risk of some distortion. You could use mains-rated caps (X or Y), as these are guaranteed not to fail short circuit.
Resources saved on this page: MySQL 18.75%
