Hammond 1650P vs 1650N For EL34 PP
Old 1st April 2012, 06:07 AM   #1
MVZIK is offline MVZIK  Singapore
Default Hammond 1650P vs 1650N For EL34 PP
I know there are lots of discussions about these trannies but non really answered my question so I write in to seek some help. Will there be an audible difference using the 1650P(6.6k CT) which are less favorable in the EL34PP application comparing to the 1650N(4.3k CT). Also I heard the "P" will give out lesser watts with EL34 comparing to the "N" how much lesser? Thanks.
Old 3rd April 2012, 07:12 AM   #2
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
if you connect your 8ohm speaker to the 16ohm tap, you will get more power as you end up with 3.3k reflected load at primary....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 3rd April 2012, 09:51 AM   #3
Default 1650P for EL34 PP Amp
Thanks Tony,
someone built the amp for me using the P and I later found out that the N is actually more cut out for EL34. However I think the P are more for KT66 and 6L6which I will try out later. Now am using Sovtek 6550E. Generally I don't really find anything bad so far just wonder what the sonic difference would be if I were to have the 1650N. Apart from power output what other negative effect will there be because of this "mismatch"? Tks.
Old 3rd April 2012, 09:52 AM   #4
TonyTecson's Avatar
or kt88/6550 using the 16ohm tap....
Old 3rd April 2012, 09:53 AM   #5
TonyTecson's Avatar
are these hammonds easy to get in singapore?
Old 3rd April 2012, 12:46 PM   #6
Yes, there's a shop carrying it. Do I need to change anything in the circuit if I were to change to 16 ohm tab? Side tracking alittle I just finished building my B1 buffer preamp followed everything on the PCB and the schematics powered it up and the LED was on for a few secs and then when off. I'm using a 19v 880mA wall. 2 parts I'm not entirely sure are the D1 diode, I'm using 1N4004 which is printed on the PCB that opposed to the 914, secondly is the value of the LED, is 12v ok?
Old 3rd April 2012, 01:04 PM   #7
roline is offline roline  United States
roline's Avatar
I've tried for the 6L6 family; 6P3S, 6P3S-E 5881, EL34, Svet 6550=C= , KT88
Sweep tubes; 6JN6, 6JM6, 6CV5, 6LB6 and 6LF6 tubes all with the 1650 P iron.
For my ears, speakers ACI Orions ~3ohm connected to 4ohm, and listening room, triode mode sounds the best.....
A little less power, but more class "A" headroom. More than enough power for the speakers and listening room. 40 or the 60 watt sound about the same. I'm currently working on a ST70 like clone with old Hammond 6.6k 40watt iron, 6P3S-E 5881 output tubes. The bass in Annie's "Bare" CD is a worthy experience.
The 1650P appear to be great iron being able to be driven from most output tubes. If you are after more power don't forget the the 1650R 100 watt 5K version...... almost the same price...
SO many tubes, SO little time!!!
Old 3rd April 2012, 02:57 PM   #8
Tks Roline nice tubes indeed. Have you tried KT66? I think they will sound great with the P. Why did you opt for P rather than N for you design?
Old 3rd April 2012, 08:48 PM   #9
roline's Avatar
When I started to design tube amps I found an interesting graph of class A vs AB output power. I wanted a compromise with a larger class A operating zone without giving up too much power. I wanted a universal transformer that I could drive with an assortment of output tubes. My concern was the output impedance. The higher the Ra, the larger the iron impedance needs to be. Thus a decision was made on 6.6k.
I design 2 different platforms, sweep tubes and the 6L6 family.
Both are PCB based, just because I find it easier and it works great! I goal was to design amps that others could make by the toner transfer method.
A pic of the little Russian 6P3S 6L6 tube at 360 VB+ with a little blue glow..
Old 4th April 2012, 01:51 PM   #10
Hi Roline,
Have you used the 16 ohm tab to connect to an 8 ohm speakers? What's the pros and cons doing that? Do you need to change your circuit if you change the tabs? tks.
Hammond 1650P vs 1650N For EL34 PPHide this!Advertise here!
Hammond 1650n and Dynaco mark III circuit. mr2racer Tubes / Valves 16 14th December 2010 02:35 AM
Hammond 1650P for KT88 PP - any experience? Mario Pankov Tubes / Valves 4 20th December 2008 05:15 PM
Which do you prefer - EL84 UL PP or EL34 Triode PP - and why? ray_moth Tubes / Valves 4 23rd February 2007 12:22 PM
El34 PP Vs. El34 PSE alexmoose Tubes / Valves 47 6th September 2006 05:44 PM
