Revision 2. Balanced - Page 3 - diyAudio
Old 1st April 2012, 09:02 PM   #21
BRSHiFi is offline BRSHiFi  United States
Previously known as kingden
How is this for a driver?
Old 1st April 2012, 11:49 PM   #22
Pretend the input transformer is there, I will add an updated schematic later.
Old 2nd April 2012, 04:50 PM   #23
I added on the transformer but I have a few questions regarding the impedance and the DC resistance of the coils.
I looked up the specs on the Jensen transformer and found:
- Input impedance (primary) at 1k = 14.1k.
- DC resistance of primary = 2.26k ohms.
- DC resistance of secondary = 1.9k.
The source driving the transformer will be a floating differential signal. I am a bit confused on how to configure the setup to make the input impedance 100k ohms. Should I just put a 47k ohm in series with the + and - inputs and the transformer winding? Should I tie anything to ground here?
Old 2nd April 2012, 09:58 PM   #24
Shoog's Avatar
You cannot realistically get an input transformer to give more than its rated impedance and it will have an optimal loading impedance which will prevent it from ringing. Basically whatever that loading is you are advised to apply to the secondary and that will help to define the actual impedance of the transformer - which will be somewhat no linear with frequency.
R93 & R94 are no longer defining the input impedance. Are you certain that you will be using a none centertapped input transformer - a CT one would work better.
None of this really matters to the circuit as any self respecting preamp will be able to drive an input impedance down to 10kohms and so you need to just use what is prescribed for the transformer.
As for DC impedance - this is not really relevant unless you are passing DC through the transformer - it should not effect the transformer ratio.
As for your feedback arrangement. You have gone from a relatively straightforward ratio to ground, to a situation where the ground leg is through the other half of the differential pair cascade. This will have increased the impedance to ground many times over - so the first thing that you need to do is define the impedance up through the differential partner and back to the power supply. What might complicate the matter even more is that this impedance will probably vary with signal.
Shoog
Old 2nd April 2012, 10:15 PM   #25
How would you change the feedback configuration?
Old 2nd April 2012, 11:39 PM   #26
So you are saying just ditch the CCS and use the transformer?
EAS Controller revision A pra3718 Chip Amps 9 8th March 2011 09:31 AM
Northcreek Okara Revision Question mevaniuck Multi-Way 3 2nd July 2006 07:15 AM
Cheap 24/96 DAC, Revision B. jwb Digital Source 235 28th June 2006 08:46 AM
Copyright 1999-2017 diyAudio
