Revision 2. Balanced - Page 2 - diyAudio
Old 1st April 2012, 02:12 AM   #11
BRSHiFi is offline BRSHiFi  United States
Previously known as kingden
I switched the driver to a differential stage. I am trying to apply the negative feedback. Is it possible to somehow inject feedback along with the audio input source into the same grid?
With an op-amp you can, but it is ineffective trying to set up the tube differential stage like an op-amp using global feedback.
Old 1st April 2012, 02:47 AM   #12
tomchr is online now tomchr  Canada
tomchr's Avatar
Sure. Same way as you would with an op-amp.
What do you mean by "ineffective"? Converting the SRPP input stage you have to a diff pair would reduce the tube count by two tubes. Though, I wonder if you could build a combination. Sorta like a diff pair with active load. Way overkill for the application, probably, but it could be fun to try.
For an example of a differential amp with global negative feedback, have a look at Morgan Jones' "Crystal Palace" amp. It's featured in his book, "Valve Amplifiers" 3rd ed. I'm sure it'll be in the 4th edition as well, when that comes out that is.
~Tom
Modulus-86: 40W/8Ω @ 0.000061% THD. HP-1: 3W/20Ω, 450mW/300Ω @ 0.000032% THD. DG300B and Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 1st April 2012, 02:55 AM   #13
This is what I mean. I set it up the same way as you would a differential amplifier with an op-amp. With this circuit the FB is coming off of the 8 ohm transformer winding.
The gain is not reduced no matter what resistor combination I use. That is what I mean by ineffective.
Old 1st April 2012, 12:31 PM   #14
Shoog's Avatar
I am seeing a few people using LM type chips in the front end of a differential pair, which is in my opinion is just not adequate for the intended job. I think they are adequate for under output tubes - but simply do not have a linear or high enough impedance for the critical input stage. The signal will fall out of balance above about 10khz producing all sorts of nasty harmonic distortions.
Its so simple to build a two transistor CCS for this application that it's just criminal to use a LM chip.
Shoog
Old 1st April 2012, 02:15 PM   #15
HpW is offline HpW  Switzerland
Shoog
My general question on CCS, while currently I do not have any practicable & else experiences on this. What is the benefit (THD or else) to have a CCS compared to resistor based. May the result is may also tube depended?
Hp
Download FFT Analyzer & Generator at www.hpw-works.com
Old 1st April 2012, 02:37 PM   #16
Shoog's Avatar
The stiffer the tail the better the phase balance. Effectively you are forcing the LTP to send all the signal between the cathodes, which acts as an input just like g1, The stiffer the tail the more perfect the signal transference between input valves. So the tail has to be many time higher impedance than the the valve impedance - and it is very easy to achieve with a two transistor current source. Using a resistor which is difficult to make many times higher than the valve impedance means that a substantial part of the signal can bleed away to earth via the tail.
If, as in this case, the two inputs are been driven - having a stiff tail forces the input stage to integrate any difference between the inputs.
Its a simple matter of if you are going to use a LTP - you might as well do it properly and use as stiff a tail load as possible. LM chips have a reducing impedance above about 10khz which not only makes them a poor tail load above these frequences - but also makes in a variable load with frequency.
Shoog
Old 1st April 2012, 02:41 PM   #17
I can correct the tail problems later and I have thought about that.
What I am asking in the interm is how do you apply the feedback?
Old 1st April 2012, 02:48 PM   #18
Shoog's Avatar
Use exactly the same cathode resistors you had originally but simply reference them to your CCS common node rather than ground. This may require another -B to give the CCS room to function.
Shoog
Old 1st April 2012, 02:50 PM   #19
Then I will look into a cascode of 3904 Q's to replace the 334? Sound good?
Old 1st April 2012, 02:55 PM   #20
Shoog's Avatar
Sounds excellent.
The suggestion about combining your two bias arrangements should work - but it will probably alter the feedback and I wouldn't like to hazard a guess at how to calculate it. It maybe a matter of experimentation with a pot to see what actually sounds best.
Shoog
EAS Controller revision A pra3718 Chip Amps 9 8th March 2011 09:31 AM
Northcreek Okara Revision Question mevaniuck Multi-Way 3 2nd July 2006 07:15 AM
Cheap 24/96 DAC, Revision B. jwb Digital Source 235 28th June 2006 08:46 AM
Copyright 1999-2017 diyAudio
