Old 30th March 2012, 04:40 PM   #1
phrarod is offline phrarod  United States
Default 6h23N test setting?
I need to test a pair of 6H23N tubes to find which one has the best matched sections. I have a TV3 Military tester.
Is it alright to use the 6922/6DJ8 settings or is there a better set of numbers to use?
Much appreciated.
Old 30th March 2012, 04:54 PM   #2
They are slightly different, 6N23P has a little higher max plate V and heater I (beside some other small differences). You can test it as 6922/6DJ8.
E88CC is different from them.
Old 30th March 2012, 04:56 PM   #3
So I am safe at least for not damaging the tubes and just matching sections in my tube tester set at 6922/6DJ8?
Old 30th March 2012, 05:00 PM   #4
Yes, don't worry, you are safe to test them. Before doing it check if pinouts are the same (i think they are), datasheets have easy to read info
Old 30th March 2012, 05:03 PM   #5
Pin outs are the same. Thanks so much for the help!
Old 30th March 2012, 05:05 PM   #6
http://www.triodeel.com/6dj8_p1.gif
http://www.goldenmiddle.com/files/6N23P.pdf
You might want to learn what an E88CC is, see it's datasheet here:
http://www.hifitubes.nl/weblog/wp-co...lips-e88cc.pdf
Why do you need to match triodes? Do you have schematic?
Old 30th March 2012, 07:03 PM   #7
Sections match. Thanks for the data sheets. This is a circuit that needs balanced halves because its splits a signal. No schematic.
Setting up a 2.1 system Rockyaudio Everything Else 0 12th September 2011 09:17 PM
Is there any test cd to test jitter using a scope ? gaetan8888 Digital Source 4 10th August 2007 09:24 AM
bias setting ben goh Solid State 8 14th August 2006 04:26 PM
Setting up a 3-way system LEESTER Car Audio 12 4th April 2006 10:16 PM
the best setting A'af Digital Source 0 19th January 2002 07:18 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
