Triode curves for EL/PL519
Old 29th March 2012, 12:17 AM   #1
Adolf Corkscrew is offline Adolf Corkscrew  Finland
Default Triode curves for EL/PL519
Hey,
I was looking for triode curves on the EL/PL519, but found nothing on the goode olde google. I was thinking of making a push-pull amp in Class A triode mode with some of the PL519's I happen to have around. But the Philips datasheet only gives a single pentode curve set... So, if any of you have any idea where to find a decent triode curve set, please share the info with me.
Old 29th March 2012, 01:18 AM   #2
gcwills is offline gcwills  Australia
Sorry - don't have triode curves for the '519 but I have successfully used triode strapped/ UL line output valves with great results in the past. The thing to watch is that the screen voltage ratings limit HT in your amp to this rating. I have used a supply of +300V for 6CM5/EL36 which is 50V higher than the databook screen rating - wouldn't like to go much higher! The '519 has the same 250V max screen rating.
Old 29th March 2012, 01:25 AM   #3
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
It is not screen voltage rating that you should worry about, it is screen power dissipation that depends on screen current and voltage. In pentode mode when anode voltage goes below screen grid voltage screen grid current goes sharply up. In triode mode it does not happen.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 29th March 2012, 06:02 AM   #4
jane is offline jane  Norway
jane's Avatar
Here are triode curves for EL509/6KG6:
Audiofil - feel the sound - forum: PL504 + Visaton TR84
Life is hard - Then you die.
Old 29th March 2012, 10:38 AM   #5
Thank you for this. The PL519 and 509 should be electrically quite similar, the former only having slightly higher ratings, if I remember right?
So, in triode the plate resistance seems to be ridiculously low, but also is very low, so driving this will take some grunt... Then again, with low rp, the winding ratio will be smaller than with the likes of KT88 and such, so maybe the low won't be such a problem.
Old 29th March 2012, 10:44 AM   #6
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Tom made them all , and those are not the sims
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 29th March 2012, 01:13 PM   #7
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
i believe that a resistor from screen tied to plate is used to make sure that plate voltage stays on top of screen voltage....said another way, the resistor ensures that screen voltage stays lower than plate voltage....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 29th March 2012, 01:44 PM   #8
avincenty is offline avincenty  United States
It is a loss that his site is not active anymore, it had good stuff.
Alfredo
Old 29th March 2012, 03:54 PM   #9
Wavebourn's Avatar
One more:
Old 30th March 2012, 07:04 AM   #10
aardvarkash10 is online now aardvarkash10  New Zealand
aardvarkash10's Avatar
Alfredo
pm Tom - he's pretty good at sending stuff to individuals. Not so much 'bots...
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile,
Triode curves for EL/PL519Hide this!Advertise here!
814 triode curves ailouros6 Tubes / Valves 19 11th March 2017 09:42 PM
Triode curves for 6AU5 boergars Tubes / Valves 9 27th November 2015 10:45 PM
828 Triode Curves? lakeside Tubes / Valves 3 15th May 2012 07:23 PM
7788 Triode Curves dsavitsk Tubes / Valves 89 21st July 2011 09:27 PM
Derive Triode Curves from Pentode Curves? dsavitsk Tubes / Valves 3 14th May 2007 06:10 PM
