Is that a SRPP circuit with 6SN7?
Old 1st April 2012, 04:22 PM   #11
DF96 is offline DF96  England
You need to ask your friend what he wants to achieve. These 'upgrades' may actually be a complete transplant: a new preamp in the old box. In many cases the 'best' preamp is no preamp at all, as a typical CD-based system does not need extra gain.
Old 1st April 2012, 04:33 PM   #12
Tubenstein is offline Tubenstein
Yes, you are right for "concept" in certain way. We group of friends has tried that, with no dynamics!! Gain is not an issue when dealing with CD player but what about impedance?? Impedance mismatch ruins everything.
Many mfg has built their CD player with direct output with volume pot, never success. The most important part is my friend is a vinyl guy. And he has the Counterpoint SA-9.
Old 1st April 2012, 04:41 PM   #13
Almost all audio systems are intended to operate with severe impedance mismatch. Low source impedance, high load impedance is the correct way. The last thing you want in an audio system is impedance matching!
As long as you don't have long interconnects (high capacitance), high value volume pots (high and varying source impedance) or amps with low and non-linear input impedance it should be fine. The perceived lack of "dynamics" might simply be due to a lack of low-order distortion and a reduction in noise.
Old 8th April 2012, 10:57 PM   #14
ruffrecords is offline ruffrecords  United Kingdom
ruffrecords's Avatar
It is a high current mu follower. The tubes are simply paralleled for higher current capacity.
Cheers
Ian
Is that a SRPP circuit with 6SN7?Hide this!Advertise here!
6SN7 SRPP - oscillating dc offset lordearl Tubes / Valves 65 1st March 2014 11:25 AM
With painted a circuit, STI(2SK182E) pipe of the SRPP circuit, is feasible? lgqliu Solid State 2 25th February 2012 06:07 PM
6SN7 SRPP preamp BadassBob Tubes / Valves 9 28th September 2010 10:47 PM
SRPP circuit question pwgtang Tubes / Valves 20 22nd July 2008 03:25 AM
Preamp with 6sn7 & 6sl7 SRPP ??? Gregouille Tubes / Valves 4 18th June 2002 10:41 PM
