KT33 Push Pull
KT33 Push Pull
Old 28th March 2012, 03:15 PM   #1
thevalvekid is offline thevalvekid  Australia
Default KT33 Push Pull
Hi all,
I recently picked up a quad of NOS GEC KT33C's and I was looking to build a low power, all-octal AB1 PP amp around them.
I have a pair of 4k3 UL OPT's I can use, which are close enough to the 4K the datasheet recommends.
Does anyone have any experience with these?
There doesn't seem to be much info around on them.
Thanks!
Old 28th March 2012, 04:25 PM   #2
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
This transformer should work since impedance point of view, but check that wires supports current flowing in the windings, and that core will not saturate with the voltage difference between plate and plate at full plate voltage excursion.
Good luck.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
KT33 Push PullHide this!Advertise here!
"Push-Pull" for push und "Push-Pull" for pull (like Gamnut) - whats the right name? tiefbassuebertr Solid State 70 15th August 2012 08:08 PM
Push-Pull vs Push-Pull-Parallel rsumperl Tubes / Valves 8 10th July 2012 05:34 PM
push pull chainenoble Subwoofers 17 28th June 2006 04:35 AM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 3rd November 2005 11:25 PM
Double push-pull versus single push-pull jraraujo Tubes / Valves 19 19th October 2002 12:23 AM
