Another Tube I/V converter/preamp for balanced DACs with SE output:build thread
Old 26th March 2012, 10:10 PM   #1
pauldune is offline pauldune  Netherlands
pauldune's Avatar
Default Another Tube Preamp for balanced DACs with SE output:build thread
A while ago I decided to purchase a DIY DAC, with the intention to build and/or design my own tube I/V converter for it. After some reading, the Buffalo III from twisted pear audio came in sight, so I bought that.
Luckily it came standard without integrated output stage, so that was ideal.
The DAC delivers 16mA/channel. (it's not per sť a current output DAC, but that is another story)
I wanted to keep it as simple as possible. So my first idea (see schematic #1) was to just take the balanced + and - out, put two 1 ohm I/V resistors between that and GND, connect the - output to the GND and the + output to the input of a voltage amp stage with reasonably low output impedance and a gain of ~70x. Ready.
I forgot that then both the (differential) -outputs would be connected to the same ground, so I had to come up with some other idea.
This is what I came up with. (schematic #2)
Again, as simple as possible. Its a standard LTP with CCS in the tail, based around D3A in triode mode. (low noise, high gain, low distortion, low plate resistance)
I calculated its gain as ~28x. With a 4.7 ohms I/V resistor, that should be enough for 2v output. It doesn't need input capacitors, in fact the 1.68V DC offset from the dac helps to put a little more voltage over the CCS.
The CCS is a 10M45S, and the lower end of the tail is -6.3V. (the 6.3v heater voltage) So the total voltage over the CCS is ~9.23V (6.3+1.25+1.68)
It's current is set to 40mA.
The D3A is set to 140v Vanode, and 20mA Ia. The output is taken (using a good quality capacitor) from the tube with the + phase, the other tube is loaded with the same load as my power amplifier.
What do you think?
Any ideas are welcome!
greetings, Paul
Old 27th March 2012, 07:32 PM   #2
pauldune's Avatar
Woops, today I read somewhere that the 10m45s only works good with Vak larger than 20v.
Kan someone confirm this?
Paul
Old 20th April 2012, 02:24 AM   #3
PET240 is offline PET240  Australia
CurIosity, is it two tubes per channel?
Have you looked at John BroskieS unbalancer from tube cad/glassware?
Just a thought, he has a CDs in the cathode of a dual triode as well.
D
Old 20th April 2012, 03:35 PM   #4
pauldune's Avatar
Yes,
2 tubes per channel; 4 tubes for stereo. This schematic has evolved into this:
http://www.diyaudio.com/forums/tubes...based-ltp.html
because I wasnt satisfied with this version.
Yes I looked at the unbalancer; part of my inspiration came from it, but I wanted a simpler schematic, and less coupling capacitors.
So I needed more gain and lower output impedance; thats why I used d3a, wich has a mu of 70 in triode, combined with under 2k output impedance. Plus it is a very low noise tube. But for optimal results it needs ccs's in the anode line, very low distortion is then possible: 0.02 % without feedback. Sounds good too...
Paul
Old 31st May 2013, 03:50 PM   #5
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
Hi Paul,
Where are you in your Bal to SE progress?
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | ExtremA | FO v1.4 | USSA5 | TSSA | Telos 390 Clone | NX Amp | FC-100
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Another Tube I/V converter/preamp for balanced DACs with SE output:build threadHide this!Advertise here!
Kaidee's Simple SE Build Thread nukaidee Tubelab 86 16th April 2010 05:37 AM
SE to Balanced tube preamp idea hollow_man Tubes / Valves 33 1st October 2009 07:44 PM
SE - Build Thread soundengine355 Solid State 6 27th June 2009 01:19 AM
My SE KT-88 Build thread athos56 Tubes / Valves 13 21st December 2008 07:16 AM
