Time relay
Time relay
Old 24th March 2012, 09:53 PM   #1
miguelnoda is offline miguelnoda  Spain
Default Time relay
Hello buy a relay time for my stage 300B and put it after the high tesion 30 seconds jumps and shakes the speaker cones.
Anyone know the exact placement for not doing this?
the device is this (Power Supply Board Action Delay 300B 2A3 KT88 tube amp) (Sophia Electric)
thanks
Old 25th March 2012, 01:07 AM   #2
dgta is offline dgta  United States
Post the schematic of the amp and power supply with the relay. Someone will be able to help you.
Old 25th March 2012, 12:28 PM   #3
Burnedfingers is offline Burnedfingers  United States
Your english needs work and its hard to understand you but I will take a guess. You bought a (Power Supply Board Action Delay 300B 2A3 KT88 tube amp) (Sophia Electric) and now the thing bangs on and your speakers shake?
Old 25th March 2012, 09:44 PM   #4
Default time delay
right, when entering the high voltage moves the cones of the speakers
Old 26th March 2012, 12:29 AM   #5
popilin is offline popilin  Argentina
popilin's Avatar
Try the relay switch-on after warm up of tubes.
You need first power the filaments, say 30 seconds.
Use a cheap speaker to test, just in case.
Or even better, short circuit the output of the amp with another relay during start up.
Old 26th March 2012, 06:55 AM   #6
LinuksGuru is offline LinuksGuru  Europe
Connect 4-5H choke in B+ in order to build CLC filter..
Old 27th March 2012, 11:13 PM   #7
Default time delay
you could make me a schema
thanks
Old 28th March 2012, 01:30 AM   #8
VaNarn is offline VaNarn  Australia
Time relay
It appears that you need to fit suppressor networks across the relay switch contacts.This is usually a 0.1mFd capacitor in series with a 100 Ohm resistor.The capacitor should be rated to suit the B+ voltage with a healthy safety margin if there are filter chokes in the supply rail.
Old 28th March 2012, 01:30 AM   #9
popilin's Avatar
thanks
Try this.
Relay contacts are conected to speakers output, short circuit in "power off", after time delay, relay is "power on" and short circuit is removed.
Need a three contacts relay.
Time delay is about 10sec. If so much, decrease R, say 470K
NEVER power up a valve amp without a load.
Old 15th September 2012, 10:58 PM   #10
Default time delay
I send the schematic to see where I put the time delay or diodes
http://Click the image to open in full size.[/IMG]
Time relayHide this!Advertise here!
B+ time delay relay cbutterworth Tubes / Valves 24 31st August 2011 12:53 PM
on/off thump - use Time Delay Relay ? redrabbit Everything Else 0 29th June 2008 02:01 AM
cheap time delay relay for soft start? mpmarino Parts 0 20th January 2007 09:47 PM
Setting the relay time on softstart HiFiNutNut Solid State 12 18th October 2005 02:18 AM
Time Delay Relay Tubes cadman Tubes / Valves 8 17th December 2002 04:25 AM
