Time relay
Time relay
Old 16th September 2012, 10:14 PM   #11
VaNarn is offline VaNarn  Australia
Time relay
Since the voltage and current ratings for the relay contacts are unknown,the obvious place for the delay switching is between the H.T.winding centre-tap and the connection to ground.
Old 16th September 2012, 11:58 PM   #12
roline is offline roline  United States
roline's Avatar
When I use damper diodes for delayed B+, I use the standard C-L-C filter for the supply hash and then add the diode and cap. This last cap becomes the Max B+ that I use to bias the output transformers. Then R-C for second stade and R-C for first stage like normal.
For the C-L-C filter be sure to use enough of a safety margine for the cap's voltage rating, stack them if you need to.
I've used this method on power amps and pre/headphone amps to prevent turn on noise, and turn on overvoltage.
SO many tubes, SO little time!!!
Old 17th September 2012, 04:16 AM   #13
2wo is offline 2wo  United States
If you replace the 5U4 with a indirectly heated rectifier, you won't need the delay circuit at all...John
Time relayHide this!Advertise here!
B+ time delay relay cbutterworth Tubes / Valves 24 31st August 2011 12:53 PM
on/off thump - use Time Delay Relay ? redrabbit Everything Else 0 29th June 2008 02:01 AM
cheap time delay relay for soft start? mpmarino Parts 0 20th January 2007 09:47 PM
Setting the relay time on softstart HiFiNutNut Solid State 12 18th October 2005 02:18 AM
Time Delay Relay Tubes cadman Tubes / Valves 8 17th December 2002 04:25 AM
