My first DIY schematic... need eagle eyes.! - Page 3 - diyAudio
Old 29th March 2012, 10:52 PM   #21
Greetings from FixitLand!
Re the EF80 (AKA 6BX6)...looks rather like a 6AU6 on a B9A base. Thanks for the info; I'd been thinking of trying a pair of 6AU6s out as a flea-power amp just for laughs, and this makes it seem more likely to actually work.
Take care,
J. E. Knox "The Victor Freak"
Old 30th March 2012, 10:54 AM   #22
Has anyone tried ECC99 as a power triode? http://www.jj-electronic.sk/pdf/ECC99.pdf
looks like it'd be good in something like this.
Old 30th March 2012, 02:15 PM   #23
MelB is offline MelB  Canada
Dude, with a 290AX you are going to end up with well over 400 volts on that 12au7.
That puts you right "off the chart" The curves I can find only go to 375v.
I'd start with -30 volts as a bias. You'd want 6K PER cathode. I'd go with separate cathode resistors as well. You will be totally maxing these tubes out. Start with a high cathode resistance and work your way down. That would be my approach.
Also this will require a lot of dicking around. Put a bleeder resistor on there for starters so you don't kill yourself.
Old 30th March 2012, 02:33 PM   #24
dirkwright's Avatar
Try a 12BH7 instead of the 12AU7.
Old 31st March 2012, 12:48 AM   #25
shonen is offline shonen  United States
Hey dude... thanks, I am planning to step it down to around 300V somehow. Method not yet decided. The 125A OT arrived and it is teeeeeny!
Old 31st March 2012, 04:32 AM   #26
If you use a choke for filtering start off with it before the first cap. Lower voltage and better regulation ... if you think that's a good thing. Try running both Pi and choke input filters with that tranny in the Duncan supply modeler.
Old 1st April 2012, 12:46 AM   #27
That's what I was wondering. An isolated choke vs taking power off the preamp rail after the first cap / resistor... thanks. gonna try to get a model working so I can kill myself virtually..
btw, ever use SPICE? i'm on linux primarily and have gEDA installed. have a feeling this will kill an entire day to get working as a tube amp simulator.
Old 1st April 2012, 03:47 AM   #28
If you don't have a choke in there already a resistor before the cap will do the job. It will be a lot smaller than a dropping resistor - even 100R will probably be enough.
Remember: you don't hear with your eyes.... Elvee Solid State 27 4th April 2011 06:39 AM
First try at an Eagle Schematic/board athos56 Tubes / Valves 15 4th November 2009 06:15 AM
Blu Eyes Amplifier Tyimo Solid State 4 22nd July 2008 04:41 PM
can this headphone amp be such a ****? or is there something wrong in my eyes? facundonu Headphone Systems 9 1st August 2006 06:14 AM
Copyright 1999-2017 diyAudio
