#21 |
#22 | |
But in your case NFB is not a problem. You have oscillation without it too. So it either ground or power filtering or physical layout problem. You need to address it first before working on GNFB. |
#23 | |
Do you see this 20 mv (P-P) hum with input shorted? If so, you power filtering is not adequate. Are you sure that ALL your electrolytic capacitors are functional? |
#24 | |
But at the moment oscillation at LTP 6N6P is a problem #1. As Geek from DIYTube.com suggested, 6N6P is prone to oscillation which is very difficult to get rid of. I'm going to buy 12BH7 (original schematic used them), and 6CG7 (very linear triodes). So I will try to use these tubes instead of 6N6P. |
#25 | |
I'm certainly need to refresh my math skills back to my student days. Here are oscillograms of 20 KHz input/output. Can you please point to the reference how to calculate these RC values? |
#26 |
One point measurement won't help. You need to cover all frequency range from 20 Hz to 500 kHz. An example: one amplifier I measured recently had problem with stability at 280 kHz.
#27 | |
At 207 KHz input and output signals are completely out of phase. This amp have quite large output transformer (4.5 Kg, or 9.92 lbs), so it is not meant for so high frequencies as 500 KHz, because transformer of that size at 500 KHz will act like a capacitor. |
| Stubborn Oscillation | kingneb | Tubes / Valves | 118 | 24th March 2012 08:09 PM |
| PPI PC2350 RF Noise or Self oscillation problem | soft4gsm | Car Audio | 9 | 11th December 2010 11:31 AM |
| LT108 Oscillation sounds like tube rush/white noise | Hearinspace | Tubes / Valves | 5 | 31st July 2010 05:52 PM |
| I don't even know what to call this- | Conrad Hoffman | Everything Else | 16 | 24th June 2007 04:11 PM |
| call me embarassed! | shepperd | Class D | 2 | 6th February 2007 09:56 PM |
