What is the biggest 300B tube? (Dimension)
Old 22nd March 2012, 02:41 PM   #1
Join is offline Join  Norway
Default What is the biggest 300B tube? (Dimension)
Hi!
I got one project running and it will use 300B's. What is the biggest size of 300B that is out there?
There is a lot of types out there, but lenght are not always mentioned.
I do not want to limit tube selection due to a too small cage or space for it.
Like TJ300B mesh type is 15,5mm long plus the pins. Is this the longest one? http://www.emissionlabs.com/datashee...mesh-final.htm
Thanks for any help.
-join-
Old 22nd March 2012, 05:48 PM   #2
kevinkr's Avatar
Some of the tubes made by Vaic and AVVT were quite large, there are still small stocks of these tubes NOS and they show up used from time to time as well. Jac music would have information on these.
The 300B tube history. What history?! It is alive!
Also Kron currently produces the 300B as well: Tubes
The TJ globes are quite physically large compared to the generic ST glass versions..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 23rd March 2012, 09:55 AM   #3
Thanks!
I will make the cage around 20cm high then.
-john-
What is the biggest 300B tube? (Dimension)Hide this!Advertise here!
Tube dimension versus SPL mike34 Subwoofers 15 7th March 2016 09:07 PM
300b tube life duderduderini Tubes / Valves 6 3rd December 2012 05:11 PM
300b tube cage dsavitsk Tubes / Valves 15 23rd January 2010 11:29 PM
Is my 300B tube dead? Evenharmonics Tubes / Valves 5 25th May 2009 05:51 PM
Biggest dual triode output tube? leadbelly Tubes / Valves 3 30th July 2007 09:57 PM
