Musical Machine (triode PP EL34) question(s) - Page 5 - diyAudio
Old 21st February 2013, 08:19 PM   #41
boywonder's Avatar
It looks like Tinitus' circuit in post 31 will also work if the wiper goes open......
at least to my semi-newbie eyes......
Old 21st February 2013, 08:34 PM   #42
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
I was told to do it that way by a master member
curcuit was drawn by me, but approved as shown
and thats about all I know about it
Old 22nd February 2013, 03:29 AM   #43
mr2racer's Avatar
Better?
Old 22nd February 2013, 04:26 AM   #44
boywonder's Avatar
Originally Posted by mr2racer View Post
Better?
nope. If the wiper lifts, your tubes are "full on". Study the circuit in post #29 or post #31, At least one bias circuit resistor needs to connect to the tube grid without going through the pot wiper. That way, if the pot goes open, the grid is still connected to the -ve bias voltage.
Old 22nd February 2013, 05:04 AM   #45
mr2racer's Avatar
And the 37k resistor isn't between the supply and the grid even if the wiper lifts? If the wiper lifts the 37k/22k voltage divider comes into play alone. The output voltage from which is about 27 volts not zero? (Which needs tweaking as it is a bit too high.)
Old 22nd February 2013, 02:50 PM   #46
boywonder's Avatar
Sorry, yes. What you have works.....had to turn my head sideways to see it....
I think your R values need tweaking though. I would shoot for an adjustment of about -20V to -35V or so on the grid.
Old 22nd February 2013, 03:59 PM   #47
boywonder's Avatar
Kevin: Here is what I came up with......please check the math. It appears a 10K pot does not give much voltage adjustment unless lots of bias current is flowing to ground. This circuit is using between 2.1-2.8 ma of bias current to ground.
Old 22nd February 2013, 10:16 PM   #48
shouldnt there be resistor in series with wiper ?
looks a bit naked
anyway, I thought it would take some of the load ?
I suppose the 'security' resistor in paralel with pot/wiper also does that, as a side effect ?
or are they 'just there' ?
Old 23rd February 2013, 04:27 PM   #49
mr2racer's Avatar
Thanks guys, I'm glad I finally got it right. I already have some nice Bourns 10k PCB mount pots I may return them for 20k if Digikey has them. I'm using an Antek AN0124 transformer here 2 x 24 volts at 210ma. I'm going to build the boards and the rectifier and see what I get for voltage. Then put in the values I need. The bias will drw something like .001125 of current so the transformer output should be near peak.
Old 25th February 2013, 11:49 PM   #50
mr2racer's Avatar
Hello Again All,
Can anyone tell me what wattage the 100ohm pot in the CCS needs to be? And is it just connected on the one end and the wiper? And does all the DC current go to ground through the lower tubes grid?
Kevin
EL34 Musical Machine Output XFMR suggestions greyhorse Tubes / Valves 4 10th June 2011 02:32 AM
EL34 PP triode mode hums slideman82 Tubes / Valves 5 11th March 2011 04:51 AM
FS: parts for Musical Machine PP 6V6 amp jrebman Swap Meet 5 28th October 2009 09:27 PM
Which do you prefer - EL84 UL PP or EL34 Triode PP - and why? ray_moth Tubes / Valves 4 23rd February 2007 01:22 PM
Copyright 1999-2017 diyAudio
