Musical Machine (triode PP EL34) question(s)
Old 17th February 2013, 06:23 PM   #31
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
I was tought to do it like this
something to do with safety
that is, if I have drawn it ok
Old 17th February 2013, 07:04 PM   #32
mr2racer is offline mr2racer  United States
mr2racer's Avatar
Default Correction
Thanks Tinitus,
I think it amounts to the same thing. Two voltage dividers in parallel. One variable and the other set. I think I have it right nowThe lower set divider, 37/22k divider yields 24.6 volts. The adjustable divider, 27/10/22k yields between 24.6 and 35.8 volts. Which makes gives the same range of adjustment as the original design. But if the wiper fails the minimum bias voltage becomes 24.6, the set divider output.
Old 18th February 2013, 11:24 PM   #33
mr2racer's Avatar
Hey All,
I was looking at Poindexters schematic just now and he labels the plate as 6. From my information the plate is 5. And 6 is not connected? Is this a typo?
Old 19th February 2013, 12:49 AM   #34
boywonder is offline boywonder  United States
boywonder's Avatar
Originally Posted by mr2racer View Post
Hey All,
Assuming that you are talking about the 6GK5, you are correct; the plate is pin 5. On the Poinz schemo I have, he has the upper 6GK5 plate labeled as 5 and the lower 6GK5 labeled as 6........a typo.
Old 19th February 2013, 01:49 AM   #35
mr2racer's Avatar
Thanks, I thought so. On mine the upper is hard to read and the lower is clearly a six. I'm building some boards and needed to know for sure.
Old 21st February 2013, 01:39 AM   #36
mr2racer's Avatar
Default CCS
Hey All,
I'm trying to understand how a constant current source functions using load lines. I'm assuming that if current is set, in this case at 8ma per tube. And maximum input is .785 volts in either direction, centered at .5 volts. The voltage swing would be about 78 volts with maximum output of .92 watts and 115 volts @8ma.
Math is not my strong point. But do these calculations seem accurate? I've included a graph that I hope shows what I'm thinking.
Old 21st February 2013, 02:00 AM   #37
scott17 is offline scott17
Do you mean .785V/2? If you mean .785 + and - then you will go beyond the 0V grid. Maybe -1V is a better bias point?
Hey All,
Old 21st February 2013, 10:18 AM   #38
mr2racer's Avatar
So you can still set the bias point? I guess you would still be able to by doing the calculation for the cathode resistor. The ma doesn't change much but the voltage does. So if the input voltage maxes out at .785 the input range is between 0 and .785? Not +.785 and -.785?
Old 21st February 2013, 02:30 PM   #39
I found the 6GK5/EL34 schematic using the 10M45S for the LTP CCS. I should have read through the thread and actually knew what I was commenting on, before I commented about the bias.
It appears that the input voltage would be 0.785V P-P.
Old 21st February 2013, 05:41 PM   #40
boywonder's Avatar
Kevin: Your revised bias schemo in post # 32 doesn't help when the pot wiper goes open, it just burns more current from the bias circuit from the additional resistors in parallel.
Take another look at the schematic I posted in post #29; the extra R divider chain connects to the grids.
Musical Machine (triode PP EL34) question(s)Hide this!Advertise here!
EL34 Musical Machine Output XFMR suggestions greyhorse Tubes / Valves 4 10th June 2011 01:32 AM
EL34 PP triode mode hums slideman82 Tubes / Valves 5 11th March 2011 03:51 AM
FS: parts for Musical Machine PP 6V6 amp jrebman Swap Meet 5 28th October 2009 08:27 PM
Which do you prefer - EL84 UL PP or EL34 Triode PP - and why? ray_moth Tubes / Valves 4 23rd February 2007 12:22 PM
Copyright ©1999-2017 diyAudio
