Constant Current Sources in Tube Amps
Old 2nd October 2003, 07:15 PM   #21
runeight is offline runeight  United States
Tim, I assume you mean this?
If so, here is the current regulation (green=driven, red=strapped):
The GK strapped configuration shows about 26uA. Much worse than the 0.5uA when the grid is driven.
Old 2nd October 2003, 07:30 PM   #22
On Hiatus
SY's Avatar
Perhaps they are, but are we straining out gnats while swallowing camels?
We're doing that when we use tubes in the first place.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 2nd October 2003, 08:07 PM   #23
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Yes. Except, you can get rid of the 10k between stages and adjust the screen supply resistor for operating point.
Not suprising, it's running purely on plate resistance (high though it may be), rather than amplifying the error signal. Likewise, it'll also trash out pretty good when driving anything.
Oh - how about putting a CCS in place of the "current sense" resistor? I bet that would perfect it.
Thanks for satisfying my curiosity,
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 2nd October 2003, 10:31 PM   #24
Good idea. Kind of an infinitely recursive design. Each CCS with another CCS inside of it. I like it.
One last thing on the pentode option. I thought I would try a 6BM8 because it is a triode/pentode package and because I have the model. The pentode has half the S of the 6JC6. I wondered if it would work. Also, you get your triode and pentode in the same bottle. Only two sockets for a stereo line stage.
Here's the diagram.
To get both devices into good operating region (as I judge it) I raised the B+ to 400V. Idle current is about 4.6mA.
Here is the current draw with a .05v 1KHz input signal. Again the fourier transform:
Still below 1ua and so, from the perspective of simulation vs. reality, no different from the 6JC6.
The gain is almost twice the previous configuration. Here is the 2nd harmonic for about the same output voltage:
About 0.25%.
And, finally, the response curve:
My conclusion is that if you really want to use a pentode as the CCS device, except for the PS change, this is a pretty good option.
Frank, I wonder if a 6GV8 would be a better choice?
However, all of this work still tells me that a triode pair will be just as good. You can get them two to a package too, while keeping a reasonable supply voltage.
Old 2nd October 2003, 10:59 PM   #25
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Not necessarilly, that's a fine reg. for low current/ low voltage demands though....around 200 to 250VDC @ 5 mA at most.
One of my favourites is the ECL82/6BM8 for lowish voltages.
Frank
Old 3rd October 2003, 08:02 AM   #26
cyril is offline cyril  United Kingdom
Good work that you are doing.
Here is a link that you may wish to read and then try in your sim.
http://www.dddac.de/at08.htm
Old 3rd October 2003, 09:58 PM   #27
fdegrove's Avatar
And what if I tell you that some penthodes can be used to replace a choke? ( Tim loves me already)
For, all things considered, this is what we're doing here except we try to keep current constant.
Moreover, I know of at least one tetrode that can mimmick a nice choke... and it ain't all that small a H value either.
There's a lot of clever things you can do with tubes...there really is no end to it.
Frank
Old 3rd October 2003, 10:58 PM   #28
PRR is offline PRR  United States
PRR's Avatar
> Kimmel says that a triode cannot be considered a true CCS since "because it hasn't enough gain...
It Depends.
The usual trick is about a 470Ω cathode resistor, with the grid tied to the bottom of that. The CCS effective impedance is then essentially Mu*(1/Gm) which is Rp which is about the same as a simple plate resistor.
Runeight is using a 20K cathode resistor. That forces 3 extra parts to keep DC bias. But then the CCS impedance is Mu*(20K+(1/Gm)). For the 6DJ8, that comes out to about 600KΩ, a very high value indeed. You get 90% of the benefit of a "perfect" CCS.
Another point: 1/Gm is 200 to 2K for most tubes, and 200Ω happens only with "best" (most fragile) tubes at high current. But with the 20K resistor, they all work about the same: you can use a rugged 12AU7 or 12AT7 instead of the 6DJ8 or other too-hot tube. The impedance then depends mostly on Mu, not Gm or the ratio of Gm to cathode bias resistance.
When you get to Pentodes: the effective Mu is very high, but you must drive the Screen to track the Cathode. The obvious way is a capacitor from Cathode to Screen. You also need a path to supply Screen current, usually a resistor. When you do all that, the Pentode's very-high Mu is swamped by loading effects. I put far less trust in the available Pentode models than the triode models, but I think Runeight is right when he shows only modest or even no improvement from a ballasted triode. You could bootstrap the screen with yet another tube, but where are we going?
As Frank says "There's a lot of clever things you can do with tubes...there really is no end to it." Recall the words of the preacher in the Bible: "Of the making of many things there is no end... there is no new thing under the sun."
I think the simulation should have a load: say the typical grid resistance and capacitance, or the IHF standard Line Out load. If you cascode and bootstrap and CCS a tube to death, you make an ideal infinite object that can't interface with any real world.
For anybody who really wants to dig: just after WWII the MIT Radiation Labs (RADAR) released a 10-volume summary of their research. One volume is general amplifiers, and talks about such things. In general, as you reduce current while keeping supply voltage high, gain rises (but bandwidth decreases). They did try near-CCS topologies. In real life, the improvement from using another tube as a CCS is not as good as using an extra tube some other way, such as another amplifier stage or a buffer. You never see such frills on commercial gear from the heyday of tubes: they knew better.
There is no remembrance of former things... Ecclesiastes 1:11
(because runeight and I smashed them with hammers....)
Old 6th October 2003, 12:06 AM   #29
Frank, you knew I would have to ask how? So I could simulate it.
PRR, thanks for the additional illumination. As always you managed to do in a few paragraphs what took me a couple of pages and several thousand drawings.
Et tu, Brute?
. . . for the former things are passed away. . . . Behold I make all things new. . . . Revelation 21:4,5
I trust we can be forgiven.
Old 6th October 2003, 09:56 AM   #30
fdegrove's Avatar
Sure....
Vb = 400V
V out = 335V
Va = 60V
Vg2 = 100V
Vg1 = -1.0V
Ik = 110mA
Rg2 = 60K
Rg1 = 470K
Rk = 50R
C in = 8.0F
C out = 20F
Cg2 = 8.0F
Cg1 = 50F
The tube used here is a 6216 as made by CBS-Hytron.
They claim this circuit emulates a 12H choke at 150mA..
Other than this application note, I fail to see anything extraordinary about this tube tube so I think it's safe to assume other penthodes can be made to work in a similar way.
Frank
Constant Current Sources in Tube AmpsHide this!Advertise here!
Is constant filament current better way to build amps? Sunsun22 Tubes / Valves 74 21st March 2008 02:40 PM
constant current sources... cathode_leak Tubes / Valves 10 29th March 2005 10:18 PM
Aleph+Constant current sources X-ZEN stefanobilliani Pass Labs 46 18th January 2005 02:53 AM
Phase splitters: Constant current sources BlackUnikorn Tubes / Valves 10 25th November 2003 02:44 AM
