Old 21st March 2012, 06:08 PM   #11
Many have run these tubes way past 250 plate volts, some close to 600V. You can easily put these in a Dynaco ST-70 with 470 volts.
Old 21st March 2012, 10:30 PM   #12
Yes they will do fine in a Dyna! I even match them at 465 volts on the plate and screen, and I've sold a number that have gone into 500+ volt applications. So I'm speaking from personal experience.
They will run at 25-30 watts dissipation all day and never show any strain.
That 250 volt figure must not be a rated maximum. I can't read Cyrillic, but I suspect that's a "typical operation" point like in western tube manuals.
Old 22nd March 2012, 12:29 AM   #13
I tried them in a few amps, no problem with 6l6 and 5881 applications. el-34 applications seem to show glowing grids and scorching patterns on the glass that match anode holes....so they won't last long in an el-34 application. bias probing them while on my tube tester puts them in the same Ip range as 6l6's and 5881's. They do sound better than 6l6's.
grid stopper and grid choke on pentode input YouAgain Tubes / Valves 3 12th February 2012 09:32 PM
FS: matched pair EH 300B Gold Grid johnsonad Swap Meet 4 25th April 2011 07:57 AM
mystery 5881 richwalters Tubes / Valves 4 22nd June 2008 07:04 AM
5881 Mas Penk Tubes / Valves 2 23rd November 2006 09:11 PM
Control grid Voltage / grid stoppers... jon_010101 Tubes / Valves 2 4th May 2006 01:59 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
