Old 19th March 2012, 02:23 PM   #1
RollE2k is online now RollE2k  Sweden
Default DN2540 CCS questions
I have a Raleigh Parafeed SET linestage, and have been thinking about modifying this to balanced operation, and i have one question about this.
I don't have any big chassis so i will have a bit trouble getting room for the DN2540's if they need sinks for each phase, so i came up with an idea. Would it be possible to make a special cascode with three DN2540's with the two "lower" ones in parallel - feeding each half of the tube and then tied together at the bias resistor. This would make me only need one big sink for the upper DN2540. I have included a picture here so you understand what i mean.. Would this work? have anybody tried it?
Old 19th March 2012, 02:26 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
nope
sources of these lower two are short circuited , so they're in fact just paralleled
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 19th March 2012, 02:41 PM   #3
Is it possible to get the same result (3-fet cascode) with any other wiring?
Old 19th March 2012, 02:46 PM   #4
Zen Mod's Avatar
nope , if you want functionality
use 2 independent cascode cells
in any case - size of heatsink , dictated by thermal demands , is adequate for 2 DN's
edit : just started to edit my post when I saw that SY already wrote what I was intending
use lower ones as naked 220's
Old 19th March 2012, 02:47 PM   #5
SY's Avatar
Remember that the "upper" device is the only one that needs heatsinking- the lower ones can be in a TO92 package or a "naked" TO220 if space is at a premium. Also, because the drains are connected to B+, the two upper devices could share a common heatsink.
If there's a sucker born every minute, where do the rest of them come from?
Old 19th March 2012, 03:31 PM   #6
zigzagflux's Avatar
Try this out:
Cascode CCS idea
Note the changes per the latest posts were done. Performance was excellent. I am mounting both devices to the same heatsink.
Old 19th March 2012, 06:12 PM   #7
I was hoping to get rid of one of the DN2540's, but i'll have a look if there is room for both on the heatsink i have. Otherwise i'll probably scrap this idea and build a completely new amp later.
DN2540 + LM317 cascode CCS? rongon Tubes / Valves 11 23rd December 2012 11:25 PM
Help on Cascode DN2540 CCS swordsman Tubes / Valves 1 24th December 2008 04:48 AM
thoughts and questions on this CCS keantoken Everything Else 9 2nd November 2008 05:38 PM
LED CCS questions... ash_dac Solid State 8 2nd October 2006 01:21 AM
Questions about a CCS-X-BOSOZ sbear Pass Labs 20 14th June 2005 02:16 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
