Assistance needed in reconstructing a Golden Tube Audio SE-40 - diyAudio
Old 18th March 2012, 08:10 PM   #1
jmillerdoc's Avatar
Default Assistance needed in reconstructing a Golden Tube Audio SE-40
I recently purchased a set of Iron from a GTA SE-40 and am wanting to point to point reconstruct it. There is a schematic over at the Yahoo Group for GTA but ot is chock full of errors. The real schematic has been elusive to say the least.
Does anyone here have much familiarity with this amp? Anyone with a good schematic by chance?
Worst case senario i could post the faulty schematic here and maybe some of you guys with advanced knowledge could help me work out the errors.
Thanks!
Jeff
Old 18th March 2012, 08:45 PM   #2
post it
Old 18th March 2012, 10:38 PM   #3
directdriver's Avatar
One channel only with no power supply.
Old 19th March 2012, 01:22 AM   #4
jmillerdoc's Avatar
Yes, the above is the schematic that has several errors on it.
Since i started this thread i was able to locate an individual (who desires to remain anonymous) who knows this amp well enough to draw the entire schematic from memory. He has given me the corrections to the above schematic and the full power supply schematic.
Soon i will have a redrawn proper schematic for the stock amp as it was from the factory. This will not be the schematic i build from however, the schematic i build from must remain unpublished at the designers request. I can say it is the same basic schematic with corrections that should have been implemented from the factory. I will post eventually the accurate factory, un-modified schematic when i get it drawn.
As many know this was a great sounding amp that was plagued be reliability issues. There is a host of information at the Yahoo GTA group on making several mods to fix and upgrade the original design.
I really appreciate the remarks so far...if anyone has any other suggestions i am still interested in what everyone has to say.
Thanks,
Jeff
Old 19th March 2012, 06:00 AM   #5
I have my friend's unit at home and thinking about tinkering with it, with his permission. Judging by the schematic, I do not like the screengrid at such high voltage--typical UL problem--that can shorten tube life and the sound is tense and not relaxed enough. Just not a fan of running tubes at such high voltage, 495vdc, just to get power. My friend and I both use high efficient speakers so power is not an issue. After extensive listening I can't say I like the sound, bland and bleached out with no tone. The kind of sound some audiophiles called "neutral" but I say boring. It does have potential. I look forward to seeing your mods.
Old 28th October 2015, 03:42 AM   #6
JRA is offline JRA  United States
Well, it's been over three years now so is the SE-40 up and running? If not or you're bored with it let me know b/c I seriously need some iron from it.
WTB: Golden Tube Audio SE 40 jmillerdoc Swap Meet 1 19th March 2012 01:33 AM
WTB: Golden Tube SE-40 OPT's jeffx Swap Meet 2 15th January 2011 12:04 AM
WTB: Golden Tube Audio SE 40 jmillerdoc Swap Meet 0 26th June 2010 01:40 AM
Can the Golden Tube Audio SE-40 SE drive 16 ohm woofers? nelsondog Everything Else 1 11th November 2007 05:00 PM
Golden Tube Audio 300B se dshortt9 Tubes / Valves 2 4th November 2005 01:30 PM
Copyright 1999-2017 diyAudio
