833A and 3-500Z Circuits
Old 18th March 2012, 06:22 PM   #1
Alchamist is offline Alchamist
Alchamist's Avatar
Default 833A and 3-500Z Circuits
Could you share 833A and 3-500Z Circuits,is it possible ? We decided to do that amplifiers but we cant find anywhere this circuit.Please could you help us about that ?
My best regards
Old 18th March 2012, 09:05 PM   #2
bear is offline bear
expert in tautology
bear's Avatar
Nothing to it.
All you need is a proper output transformer.
Also do a search here, there are discussions of these tubes, and other similar tubes.
It's just another tube, nothing particularly special other than the high high voltage which makes for a very high impedance to match to, special sockets and the requirement of air cooling. You'd also need a proper amount of swing in the driver circuit. Other than that, nothing particularly special to be done.
I would advise against working with tubes that use this sort of high voltage if you need to ask to see a schematic to make one. They are DEADLY DANGEROUS not something that anyone without extensive experience should play with. One mistake and you are instantly DEAD.
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
833A and 3-500Z CircuitsHide this!Advertise here!
SE 833A Help jmanriqu Tubes / Valves 3 22nd September 2009 08:15 PM
Amplifier using a 833A Tekko Tubes / Valves 17 15th September 2009 01:02 AM
What about the Eimac 3-500z? Toobstheway Tubes / Valves 18 8th January 2009 06:48 AM
Research on tubes and circuits simple circuits Cazcotty Tubes / Valves 6 16th June 2006 12:50 PM
85 powersupply circuits 58 charge circuits gev Power Supplies 0 31st July 2005 11:27 AM
