#11 |
Thanks Eli, well this turned into a project. I didn't test the tubes first and it appears all 4 of the EL34s were bad. I've tested them now and they are all bad, I'll never know if I fried them or they were bad in the first place. After replacing the caps and turning it on there was higher than expected voltage everywhere. I did have a speaker load connected. After 3-4 minutes of the amp being on, one of the output transformer wires burned. That's been fixed by TRS. Jim McShane introduced me to Don Sachs. Jim is putting together a kit for Don to rebuild the whole amp.
#12 |
I received my amp back from Don Sachs. He replaced all of the signal path resistors and caps, all parts and Mullard EL34 reissues from Jim McShane. Rebuilt the entire power supply and made a modification to the input stage. Don redesigned the input circuit from the 12AU7 to accomodate a 6CG7. To say I am pleased with the outcome is a gross understatement. This thing sounds incredible. I will post some pictures later.
#13 |
Here are a few pics of the complete rebuild. It sounds fantastic
| samson servo 260 advice please | gary h | Solid State | 0 | 14th December 2008 08:06 PM |
| bias pilot sa 260 | baltimoreblues | Tubes / Valves | 0 | 17th February 2008 08:55 PM |
| Pilot SA 260 bias | baltimoreblues | Tubes / Valves | 1 | 3rd February 2008 06:00 PM |
| Fischer & Tausche Capacitors | byteboy | Parts | 3 | 24th August 2004 02:02 PM |
| Fischer & Tausche Elco's | cHoc | Parts | 1 | 5th June 2003 09:15 PM |
