Old 16th March 2012, 10:57 AM   #1
Default Need VFD display filament driver
Hi ,
I have an VFD display of following type and as controller I have some samples of PT6311. I wanted to use them with MSP430 MCU of TI.
MSP430 is operating at 3.3V. I need arround -30V AC to drive this VFD's filament.
Can anyone help me on this???
Old 16th March 2012, 12:06 PM   #2
Rundmaus's Avatar
Originally Posted by avi198617 View Post
Hi ,
What exactly is -30V AC? Either it has a polarity, or it is AC...
Rundmaus
Old 16th March 2012, 12:13 PM   #3
Sorry , it was a mistake. It is AC
Old 16th March 2012, 12:32 PM   #4
Rundmaus's Avatar
Hm,
space for a small 2x15V AC transformer? How much current is needed?
Rundmaus
Old 16th March 2012, 02:09 PM   #5
Doz is offline Doz  United Kingdom
Doz's Avatar
Whoa, IIRC, the filament on VFD's is normally 3 volts, and -30 applied to the cathode to illuminate the segment.
"To err is human.. to make a real balls-up requires a computer"
Old 16th March 2012, 02:25 PM   #6
Rundmaus's Avatar
Hey there,
for VFD as well as for other tubes, the (electron emitting) filament *is* the cathode.
But you are partly right, one has to distinguish between the voltage/current to heat the filament (probably a few volts) and the 'anode voltage' between the filament and the rest of the display - this will probably be the 30V mentioned.
A datasheet for the VFD would help!
Greetings,
Rundmaus
Old 16th March 2012, 02:43 PM   #7
alexcp is offline alexcp  United States
alexcp's Avatar
avi198617, you can use an inverting switching regulator like MC33063A. The datasheet, under "application information", has all the formulae for selecting the few external components.
Old 17th March 2012, 04:36 AM   #8
Hellow to all,
The unit I am building is getting its supply from DC wall adapter & it is better if I avoid usage of transformer.
I had came across some Chinese amplifier where I found this VFD & its driver IC.
There they had used two additional winding of 3V/0.3A,28V/0.2A. For my case,
I need some converter chip to generate those from 3.3V.
I had attached VFD datasheet on previous my post..but it was bigger then the size mentioned. Anyways attaching only the relevant pages in JPEG form.
Old 17th March 2012, 04:41 AM   #9
Send a message via AIM to DigitalJunkie
Here's a link with some general info on driving VFD's.
Vacuum Fluorescent Display (VFD)
Old 17th March 2012, 05:14 AM   #10
avp1 is offline avp1  United States
You need a specialized chip. Something like these: Holtek Semiconductor - VFD Controller & Driver Series
Wtb: VFD Display muizel Swap Meet 0 1st March 2010 08:47 PM
Replacing a VFD Display with LED´s - possible? Salar Everything Else 5 12th February 2009 07:51 AM
Noritake 16x2 VFD display maxw Swap Meet 0 22nd November 2008 05:32 AM
WANTED: Replacement CD-PRO2 VFD Display Module Rarkov Parts 0 23rd August 2003 08:26 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
