Old 16th March 2012, 02:21 PM   #11
DF96 is offline DF96  England
One option would be to bias them towards the 'cold' end so the mains transformer only gets overloaded on occasional signal peaks. The issue is heat averaged over some seconds (or tens of seconds) not sudden death on overload.
Old 16th March 2012, 10:20 PM   #12
power is not everything....I have amps that can run el-34's, 6550's, kt-90's, run them most of the time with el-34's which is a power cut (225 watts) from what they would give me with kt-90's (380 watts), but I like the sound better with el-34's. the mids and highs seem more detailed with el-34's.
Accepting ones limitations Neil Groves Construction Tips 43 7th March 2013 11:50 PM
Analisys of power amp limitations of tube bias range speakerfritz Tubes / Valves 5 10th December 2011 08:27 AM
Can you help understand limitations of ClassA/G ? Bigun Solid State 86 20th August 2009 04:23 PM
Capacitor limitations?? kimschips Power Supplies 12 25th March 2005 10:29 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
