diyAudio Sponsor
Old 29th September 2003, 04:36 AM   #1
SY's Avatar
Default Fun little P-P input stage
I got slightly distracted while working on my DD ESL amp, and have been playing around with this input stage; it's a variant of a design I've been using in amps for the past 20 years or so. Main difference is the incorporation of an input transformer (there actually is no center tap on the transformer, that's a mistake on my drawing). In any case, it's good for a gain of about 20, will swing about 150V p-p, and has an f3 of about 80kHz. The balance is better than I have the capability to measure when the input resistors are well-matched.
Matching of the 2N5462s is a good idea; I used a simple test jig to match Id with a 1K resistor between source and ground. With FETs thus matched plugged into the circuit, I got plate voltages within 5 volts of one another.
Variations: for feedback, one can add 100 ohm resistors in series with each input resistor to the ground point, then run symmetrical feedback resistors from the 16 and 0 ohm taps of the output transformer secondary, grounding the 4 ohm tap. And you can get more gain and a bit more swing by bypassing the 1K cathode resistors.
This would make a dandy input stage for an ST-70.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 29th September 2003, 05:05 AM   #2
SY's Avatar
BTW, at the expense of esthetic symmetry and galvanic isolation, you can get rid of the transformer, take the input to one of the FET gates, and etiher ground the other one or use it as a feedback point.
And to get enough gain for feedback, you can also direct couple this stage to a 5692-based long tail diff amp- that's pretty much the circuit I've been using in most of my push-pull amps over the years.
Old 29th September 2003, 10:03 AM   #3
DrG is offline DrG  South Africa
Great looking circuit, SY. It's similar to something I've been toying with a "balanced" input for a hybrid amp, using bipolars.
Old 29th September 2003, 11:29 AM   #4
SY's Avatar
It's the bastard child of Dave Berning and Bill Johnson. Cross-coupled circuits are very useful for situations where one may have to use both balanced and unbalanced inputs.
Old 29th September 2003, 06:35 PM   #5
frugal-phile(tm)
planet10's Avatar
SY,
Wouldn't a CCS on the cathodes be of benefit?
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 29th September 2003, 06:53 PM   #6
SY's Avatar
Pardon me for being dumb, but I don't get what you mean. Where would I put the current source? (I know you can draw! )
Old 29th September 2003, 07:04 PM   #7
frugal-phile(tm)
planet10's Avatar
I still don't know what names go with what on a FET, so i just call it a cathode... wouldn't the -24V like to be from a current source?
dave
Old 29th September 2003, 07:07 PM   #8
SY's Avatar
No, that's the FET's drain (plate), not the source connected to the minus rail; note that the FETs are configured as source followers, where you want the drains to be at signal ground.
Old 29th September 2003, 07:08 PM   #9
Pjotr's Avatar
Maybe a current mirror is meant at the anodes? But then you end up single ended out ......
Old 29th September 2003, 07:13 PM   #10
SY's Avatar
Pjotr, no, I suspect it's reflex on Dave's part; you work with tubes too long and your brain always thinks of the minus rail going to cathodes. Easy mistake to make. I suspect he looked at the circuit and thought, "Cascode!" Which it isn't at all.
If we only had positronic tubes...
Adding a third input to a differential input stage? maudio Solid State 15 11th October 2006 02:16 AM
current bias j-fet input 2sk170 ,2sj74 at input stage YUTK Solid State 11 2nd June 2005 03:34 AM
input cap at D1 I/U stage Klaus Pass Labs 3 30th December 2003 11:00 AM
Input stage Andrey Solid State 5 21st June 2002 01:32 PM
Page generated in 0.11104 seconds (78.89% PHP - 21.11% MySQL) with 11 queries
