mono block amps with 2 x 833C overkill ? even possible to DIY? - Page 3 - diyAudio
Old 18th March 2012, 09:41 AM   #21
multi is offline multi  Australia
The 805 and 833 don't need huge voltages to run. Nobu k Shishido found they are best run at about 800 volts and 100-135 ma. Nobu used a 3.5k out put transformer in his amps for the 805.
I have made both Se And PP using the 805; I used 5k for the PP
If you can't afford inter-stage transformers you can use a Cathode follower such as a 6BL7.
The ming Da uses only 750 volts for 40-50 watts.
Phil
Old 18th March 2012, 11:05 AM   #22
FullRangeMan's Avatar
Phil
Thanks for these details.
Lampizator site inform the Ming-Da MC3008A (805 mononlock) use B+=900V, the 300B drive seems 60mA, for stated 40W, the ASL is specified in excess of 50W.
ming-da Scrool down the page.
I unaware the Ming-Da 805 OPT secondary impedance, but it could be nice to know.
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average.
Old 18th March 2012, 05:45 PM   #23
Phil
can you tell something more about the amp you made ith 805 ?
Old 18th March 2012, 08:40 PM   #24
I mean say Primary Impedance.
Old 23rd March 2012, 06:25 AM   #25
Default Nobu. K. Shishido 805
Nobu design for the 805 SE; he claims 45 watts for the 805 and 35 watts for the 838 {no top cap} with driver transformers.
Out put transformer 3.5K.
I have built 805's using about 800 volts, but driving them using 6BL7's as cathode followers, for the voltage amps I used Mu followers running at 750 volts, using 6AQ8's. A friend of mine has built the amps using driver transformers and Cathode followers, he prefers the sound of the Cathode followers.
Phil
Old 9th June 2014, 03:27 AM   #26
Default 833 Se Amp 572 SE
833 Se amp
BPA300 mono block alexw88 Group Buys 252 27th December 2011 04:35 PM
Modding Roberts/Akai mono block tube amps limey222 Tubes / Valves 4 2nd December 2006 08:50 PM
Quicksilver mini mono block amps? Burnedfingers Tubes / Valves 2 15th March 2006 12:47 PM
mono block amp Mark Osborn Solid State 11 16th March 2001 07:07 PM
Copyright 1999-2017 diyAudio
