Bias help Music Angel L$, EL84 - Page 2 - diyAudio
Old 28th March 2012, 08:05 PM   #11
vinylkid58's Avatar
The stock 6N3P's are surely Chinese. Try some Russian 6N3P-EV's, they're pretty cheap, even on ebay. Most say they are a sonic upgrade, although I don't have any exp. with these particular tubes.
jeff
Old 29th March 2012, 02:11 PM   #12
Edriz is offline Edriz  United States
Edriz's Avatar
Well I ordered some 6N3P-EV's from the tube store. Minimum order there is $10 so I had to order 8 of them. Guess Ill either keep em all or sell off 4 of them. Should be here soon. I hear that driver tubes make the biggest difference in SQ so we will see. Thank you Jeff.
I heard there is some modifications that can be done to this amp also. Maybe I'll look into that soon too.
Old 17th April 2012, 04:40 PM   #13
Edriz's Avatar
I got the 6N3P-Ev's and they are ding the same as the 5670W's.ud humming. Id sure like to find a schematic, maybe get this modded so i can eliminate those 6n3 driver tubes.
Ive searched everywhere i can think of and can not find a schematic.
Old 18th April 2012, 01:25 AM   #14
vinylkid58's Avatar
Originally Posted by Edriz View Post
I'd sure like to find a schematic, maybe get this modded so i can eliminate those 6n3 driver tubes.
The Mengyue Mini schem shows a 500R pot across the heater winding. Does your amp have this?
Eliminating the 6N3P's probably means rebuilding the amp P-P and throwing the PCB in the trash. I did see a Mini somewhere that had been rebuilt.
jeff
Old 27th April 2012, 05:54 PM   #15
Edriz's Avatar
well, I know why I was having so many isseues swapping the 6n3's. I found out this amp has 6N1's not the 6n#'s that was stated in the description. Now i know why the 5670W's didnt work out too good. I just ordered some EH 6922's for the driver replacements. I've been told that Id notice a bigger difference swapping driver tubes then I will swappin power tubes. Guess Ill find out soon enough.
What have others experienced, bigger difference in driver tubes vs. power tubes?
Old 27th April 2012, 09:34 PM   #16
Vincent77's Avatar
Well, the Mengyue schematic shows 6N2P tubes... :\
If you are absolutely sure your amp is supposed to use 6N1, buy russian 6N1P-EV tubes off ebay, they are excellent. The 6922/E88CC is NOT a direct substitute for 6N1P, even if most tube sellers say so! They are quite different tubes.
Old 28th April 2012, 10:37 AM   #17
Default Pinout difference??
Be careful with tube swapping as 6n3p(or 5670) has different pinout than 6n1p - heater is on 1&9 and for 6n1p on 4&5 so if 5670 lights-up then your amp is definitely made for 6n3p and not 6n1p.
I have an amp that came with Chinese 6n3 and putting 5670W instead improved it drastically. Later got some Soviet 6n3p-ev and they sound about the same as 5670w (but are not as pretty).
Old 2nd May 2012, 06:04 PM   #18
Edriz's Avatar
I dont know but for some reason, my amp ended up with 6N1's. I know another guy has the same one as mine and his has 6N3's. Maybe they had an over abundance of 6N1's that day. I just ordered a pair of Sovtek 6N1P hat should be here by weeks end. Ill give those a try for a week or so and maybe ill get a pair of EH-6922's. I have a friend in another forum that tells me the 6922's should work just fine. He's been an audio tech for years and specializes in tube rebuilds. We will soon see I spose.
Thanks for the help fellers, I do appreciate it. Im still open for any and all suggestions too.
Old 20th November 2012, 05:24 AM   #19
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
Besides 6N1P-EV and 6922, 6BQ7 would also work and is much cheaper.
Music Angel knutech Tubes / Valves 1 3rd June 2011 08:15 PM
Music Angel KT88 Bridged /Bias problem kongarne Tubes / Valves 1 30th January 2009 01:57 PM
Music Angel Modification Imperial Tubes / Valves 2 28th January 2008 02:13 PM
Music Angel franckM Tubes / Valves 11 10th June 2007 11:24 PM
Music Angel EL34 SimonPearse Tubes / Valves 0 27th February 2006 08:27 PM
Copyright 1999-2017 diyAudio
