Stubborn Oscillation - Page 3 - diyAudio
Old 15th March 2012, 01:23 AM   #21
Globulator's Avatar
Originally Posted by kingneb View Post
Upped grid stoppers do not help.
As far as R12 and C31 go I have a 470pF cap in there right now and a 8.2k ohm resistor.
I tried a 10k ohm pot in there and swept it. The oscillation persisted. I will try a few more caps in there.
Did you try removing the 39p cap that Wavebourne suggested?
I never understood why people add those caps either TBH.
But there again my general comment about your amp is 'Good God how many tubes, CCS's, capacitors and transformers does that feedback loop travel through?!
I'd scrap the global feedback entirely and just use localised ones instead.
Old 15th March 2012, 01:26 AM   #22
BRSHiFi is offline BRSHiFi  United States
Previously known as kingden
Yes, all my tests were without the 39pF cap.
Old 15th March 2012, 01:34 AM   #23
The sine wave shows up at the cathode as well on the 12BH7, amplitude smaller of course.
Old 15th March 2012, 01:37 AM   #24
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Increase C31 until it stops. If dies not, you have some ground loop.
The Devil is not so terrible as his math model is!
Old 15th March 2012, 01:38 AM   #25
Wavebourn's Avatar
As I suggested before, additional local loop may help.
Old 15th March 2012, 01:40 AM   #26
Will try some larger caps. I have always been under the impression that ground loops cause low frequency instability.
So you mean change the design so a local FB loop runs to the phase splitter instead of the global?
Old 15th March 2012, 01:53 AM   #27
Wavebourn's Avatar
No, I am suggesting to add one more, internal loop, through 240K 2W resistors from anodes of output tubes to anodes of driver tubes. Short parallel feedback by voltage across output tubes only. It shifts up pole caused by output resistance of driver and Miller capacitance of output triode. And it does not involve parasitic loss inductance of transformer.
Old 15th March 2012, 02:01 AM   #28
Chris Hornbeck's Avatar
There's a general procedure that allows you to actually see what you're doing, rather than just shooting in the dark, and it requires a dual-trace scope. Don't say you don't have one - you need one to do the level of work you're wanting to do.
The feedback network is disconnected at the input cathode, then loaded with a resistor equal to the load it would normally see (cathode resistor in parallel with 1/gm). One scope probe on amp input, the other on the new feedback output. Observe phase shift at various frequencies and various loads while varying lead and lag options inside the amp. Some people can work with a square wave of about 10 to 20 KHz (easily made by any computer sound card) but that takes practice and luck. Best learning and realest results come from actually plotting frequency vs. phase shift. It's easy, fun and answers your questions FOR REAL.
All good fortune,
Chris
Old 15th March 2012, 02:07 AM   #29
I have all the equipment.
Old 15th March 2012, 02:11 AM   #30
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Is it easy to damp between U56 and the cathodes with a small resistor just in case the 334 chip is acting up?
Oscillation raveenvijendren Solid State 15 18th December 2005 10:16 AM
oscillation pjpoes Chip Amps 8 7th October 2005 02:32 PM
oscillation?? wintermute Solid State 8 13th July 2005 12:45 PM
Oscillation udip Solid State 5 31st January 2005 05:43 PM
What is oscillation? jnxw2 Solid State 10 18th May 2003 11:31 PM
Copyright 1999-2017 diyAudio
