Stubborn Oscillation
Old 22nd March 2012, 06:36 PM   #101
richwalters is offline richwalters
richwalters's Avatar
[QUOTE=DF96;2955986] This is the reason why the amplifier should be as linear as possible open-loop, before you close the loop.
QUOTE]
I came across a non linear issue created by a faulty tube in a diff circuit: the global feedback loop did a perfect rescue job. This implies that your issue of non linearity before closing the loop is questionable as global feedback loop is a very powerful correcting tool.
Another example is the small signal pentode front end in a 3-4 stage power amp. The screen g2 volts can be varied, drastically effecting the stage distortion; then apply global neg feedback, and the distortion drops regardless of where g2 is set !
richy
Old 22nd March 2012, 06:45 PM   #102
Globulator is offline Globulator  United Kingdom
Globulator's Avatar
Originally Posted by DF96 View Post
Feedback works properly with a phase shift. Two ways to see this:
1. do the maths
2. trust those who can do the maths when they tell you it works
Is the maths done with music or with a sine wave?
For instance using the maths the PSRR of an SRPP is -6dB, but in reality it isn't, is it?
Richwalters:
I think then that the inverted correction signal is not affected in the same way as the original - perhaps because it's the inverse!
So if NFB works perfectly and corrects all of the non-linearities in an amplifier, how is it that all amplifiers have their own sonic signature?
Or do they all really sound the same and we're just chasing our tails?
Old 22nd March 2012, 06:52 PM   #103
M Gregg is offline M Gregg  England
LOL..
Nice one..we know they all sound the same..its just that some sound more like the same than others...
M. Gregg
Old 22nd March 2012, 07:05 PM   #104
DF96 is offline DF96  England
No feedback loop can do a "perfect rescue job". My statement that the amp should be as linear as possible before closing the loop is true. If you can halve the open loop distortion, then the extra distortion added by feedback will be only a quarter of what it would otherwise be. Of course it is possible to develop an amp which is so pathological (e.g. non-monotonic in Vout vs. Vin) that feedback can't help, which is why it is usually stipulated that a quasi-linear approximation is used - this excludes pathological horrors but includes most real amps.
The maths is not done with music or a sine wave but an arbitrary signal. Distortion is anything in the output which is not in the input.
I have never measured the PSRR of an SRPP, but in the usual balanced configuration with both cathode resistors unbypassed it will be around -6dB. If the low cathode is bypassed then it will be better, maybe -9dB. Are you saying that valves and resistors do not obey circuit theory? If your measurement differs markedly from these figures then there is something wrong with your measurement technique.
Old 22nd March 2012, 07:41 PM   #105
I don't agree or disagree with this,
However here is another take on the same feedback argument:
Go down to Negative Feedback
Lenard Audio - Education - Valve Amps
And so all amps sound the same except for phase shift caused by component distortion?
M. Gregg
Old 22nd March 2012, 07:56 PM   #106
Chris Hornbeck is offline Chris Hornbeck  United States
Chris Hornbeck's Avatar
I hate to be blunt, but this part of this webpage is a bunch of stuff that fell outta the end of a horse. Most of the rest is not bad at all. Just my opinion, of course.
Thanks,
Chris
Old 22nd March 2012, 08:00 PM   #107
Thanks,
Chris
Yes LOL nothing like food for discussion.
M. Gregg
Old 22nd March 2012, 08:02 PM   #108
Has anyone done any papers on NFB through a non-linear amplifier? The phrase 'reasonably linear' worries me as it implies a 'not notice' factor whereas I am after the best solution, not the usual boringly mediocre ones .
The earliest that I've heard of was by Baxandall and the latest is by Bruno Putzeys in Linear Audio Vol.1.
"Reasonably linear" means that we can use a simplified equation. The exact equation isn't simple, but it does exist - feedback is still completely predictable.
All good fortune,
Chris
Old 22nd March 2012, 08:15 PM   #109
The early stuff is not too bad (only a few errors) but his ideas about NFB are complete nonsense. His claim that 12dB is about the max that can be used would be surprising to the Mullard designers of the 5-20 which uses around 30dB of feedback.
What is it about feedback that seems to create such ignorance and nonsense?
Old 22nd March 2012, 08:24 PM   #110
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Yes, if you have complete mathematical models of all componsnts. I want one!
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Stubborn OscillationHide this!Advertise here!
Oscillation raveenvijendren Solid State 15 18th December 2005 10:16 AM
oscillation pjpoes Chip Amps 8 7th October 2005 02:32 PM
oscillation?? wintermute Solid State 8 13th July 2005 12:45 PM
Oscillation udip Solid State 5 31st January 2005 05:43 PM
What is oscillation? jnxw2 Solid State 10 18th May 2003 11:31 PM
