Hello all, I have a question related to my current build. Since I am using precious gu81m tubes and do not wish to see them prematurely depart this world, I'd like to implement a safety device.
I have separate boards and circuis for all voltages on board (bias, screen, anode for drivers) but I would like to have a safety device which will take out the B+ on the gu81m (1600v) if bias to mosfet stage/gu81m suddenly goes out. Can I use a thyratron? I found almost nothing on operation but I gathered a firing voltage is necessary to have conduction from cathode to anode. Can I assume the absence of grid voltage (ie bias) will shut the tube off? Please understand my concern ![]() I can find and implement a thyratron for little effort and money so that side of thing is not a problem. Also other questions: 1. the thyratron will behave like a standard gas rectifier with DC flowing through the filament transformer's CT? This would be DC however not rectified AC. Is it possible to saturate the heater core? 2. If the above has a positive answer can I solve the problem by taking the "processed" DC from the heater wires rather than through the heater transformer's center tap? 3. Are there sonic effects caused by thyratrons in the path of the b+? Thanks |
#2 |
Unfortunately, a gas thyratron is like a thyristor. Once it is fired, it stays fired until it's supply is removed.
"To err is human.. to make a real balls-up requires a computer" |
#3 |
I thought the state was voltage dependent hence the use in pulse equipment....
Just out of curiosity....what would be the effect of a thyratron on the b+ as opposed to an all ss powersupply? I don't mean as a rectifier but rather after the caps as a sound "colouring" device maybe? Inviato dal mio GT-I5800 usando Tapatalk |
#4 |
In pulse equipment, the "downside" of the pulse causes the thyratron to switch off. Some pulse forming networks employ a second "de-q'ing" thyratron to effectively short the input to ground to shut it off. You could use it as a crowbar, however, I doubt your rectifiers/ transformer will love you for long.
No idea about audio use.
#5 |
thanks a lot. that cleared the whole thyratron issue. I guess a redundant bias supply would be best for this application.
Thanks! |
#6 |
Just use a correct sized fuse
Real tubes have top-caps |
#7 |
#8 |
My objective is to protect the gu81m from accidental bias voltage failure. where could I put the fuse?
#9 | |
1. Full grounding of chassis and boards 2. fuse on each transformer 220v line 3. separate transformers for LV, HV, filament supplies 4. 20kv insulation on all HV (>500v) lines 5. plexiglass protection panes to create internal layers inside the amp 6. oversized caps for all boards 7. separate voltage sources (+600,+1600,+300+500-300+150v) 8. at least 2 cap stages for every board (in case a cap stage blows) 9. Teflon cap machined to cover all exposed HV leads 10. sofstart, timers ecc (to avoid nasty arching with the huge rectifiers) what I wanted was to protect the tubes themselves from bias failure. |
#10 | |
When bias falls away, GU81 will pull too much current (for a short period, wich it can handle) and fuse will blow.
| thyratron rectifier | sunrise | Tubes / Valves | 33 | 10th November 2008 03:16 PM |
| how to remote control a rotary switch based attenuator | Giordano | Parts | 40 | 29th October 2008 08:01 PM |
| thyratron? | Original Burnedfingers | Tubes / Valves | 6 | 7th April 2006 12:54 AM |
| Thyratron Circuit | imix500 | Tubes / Valves | 10 | 26th March 2004 04:46 PM |
