Is there any available data sheet that shows output tubes' frequency response? I know the typical "describing" words that people use (EL84s are chimey, 6L6s are glassy, etc) but is there any data out there that can actually show a particular output tube would be better suited for a particular application (bass clarity for example). Just curious, thanks.
#2 |
No, not really. The performance of an output stage is dependent on the tubes, the transformer, and the stage driving it. Without knowing all of those things, you can't predict performance. The "glassy," "chimey," "cloudy," "chocolatey" stuff about tubes is audiophile nonsense, as much as ascribing engine performance to specific types of main bearings. An amp's performance is far more dependent on overall design and execution than whether you used current production Lo Hung Dong 6V6 or 1953-vintage Achtungsbieremesse NOS EL84.
If there's a sucker born every minute, where do the rest of them come from? |
#3 |
A 6V6 is good from DC to somewhere around 10MHz. An EL84 may go a bit higher, as it is smaller.
If output valves have any effect on perception of frequency response, this will be caused by distortion masquerading as frequency imbalance. Conclusion? Don't fully trust your ears, especially when your eyes know what you have changed. |
#4 |
As mentioned by both SY and DF96, tubes themselves have relatively high bandwidth. I'll just add that it is the output transformer that forms the bandpass filter and dominates the frequency response.
The 'chime' and 'glass' character you mention is typical of guitar amp reviews, and the way a guitar amp responds is much more determined by overall design, and not what tubes in use. |
#5 | ||
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#6 | |
?I don't think that output tubes, or any tube at all, will produce harmonic distortion in the audio frequency range. But, as told by the others before, non-harmonic distortion is different between the tube types. And this means different sonic perception by the listener or the musician. Best regards! |
#7 | |
#8 | |
I actually put my OPT's on an HP 4194A impedance analyzer and had it calculate the parasitic components for me. Using those values in LTspice, the simulation predicted the LF and HF poles to within a few percent of the values I measured on the finished amp. ~Tom
21st Century Maida Regulator, Universal Filament Regulator, 300B Driver PCBs, and more... Neurochrome : : Audio - http://www.neurochrome.com/audio - Engineering : : Done : : Right |
#9 | |
#10 | |
I have been working on a monster sized breadboard that uses Plitron toroidal OPT's in P-P. The OPT's are rated for 400 watts at 20 Hz. The upper 3db point is 75KHz. Any tube that I have tried in it is capable of a frequency response of 5Hz (lower measurement limit) to 40KHz +/- 1db. It's just that some tubes are a little more powerful than others. It takes careful circuit design to make an amplifier thats not dependent on the tube type. With smaller OPT's the tube's internal impedance will affect the frequency response at both ends of the curve. A given OPT will usually have a broader frequency response when driven by a lower impedance source. Every tube has a characteristic impedance that varies with the amount of current flowing through it. Negative feedback can be used to lower a tube's internal impedance. Every tube will have an internal capacitance associated with it. This will affect how well it performs in a circuit. The tube or mosfet that is driving the output stage must have a low source impedance for it not to be affected by the output tubes capacitances. A typical amplifier design with average transformers will exhibit different frequency response with different tubes. The differences will be dependent on the circuit design and OPT quality.
| in-room frequency response & transient response | MCPete | Multi-Way | 1 | 8th October 2011 06:31 AM |
| Influence of power amplifier output coil to frequency response | PMA | Solid State | 22 | 6th May 2011 07:17 AM |
| Frequency response vs. output power | MikeW | Pass Labs | 14 | 31st January 2007 12:21 AM |
| Output transformers and frequency response | dsavitsk | Tubes / Valves | 21 | 3rd December 2006 06:48 PM |
