symptom of a dying (gain) tube
Old 12th March 2012, 03:19 PM   #1
PreSapian is offline PreSapian
Default symptom of a dying (gain) tube
what are the symptoms of an overaged tube in a preamp circuit? is it diminished bass/mid? i think i have some tubes that need changing.
Old 12th March 2012, 03:51 PM   #2
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
It sounds more like a capacitor that is changing value.
As a tube ages, the emission will decrease. The effect will be lower gain and/or the early onset of clipping at high levels.
Frank
Old 12th March 2012, 04:12 PM   #3
i should mention that the gain is also lower. it takes about 3 times the turn of the volume that is usually required to reach the desired listening level.
the whole component is fairly new and the caps should be well within their lifespan.
Old 12th March 2012, 04:33 PM   #4
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
May be that the +B is too low because of a bad cap or a false contact in the heaters rail so the tubes take more time to get normal cathode temperature.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 12th March 2012, 06:14 PM   #5
DF96 is offline DF96  England
You might get more distortion at levels below clipping. It is conceivable that your ears may perceive this as a frequency response problem, but it isn't.
symptom of a dying (gain) tubeHide this!Advertise here!
Dying breeds 503Timber The Lounge 0 31st May 2011 04:11 PM
opinion on cd700 cd-mecha error/symptom anton-sa Car Audio 0 28th August 2008 05:04 PM
help! EL84's dying buliwyf Tubes / Valves 5 23rd October 2005 06:31 PM
Symptom Diagnosis please? panos29 Multi-Way 12 18th April 2003 05:51 PM
Iron ( steel) dying Koy Solid State 6 28th August 2001 03:24 PM
