Did I get used to my amp's sound?
Old 10th March 2012, 03:34 PM   #1
kuroguy is offline kuroguy  Germany
kuroguy's Avatar
Default Did I get used to my amp's sound?
My 12at7/832 push-pull amp developed a hum in one channel. I swapped it out with a 6AU6/6AQ5 single end amp while I make repairs to it. At first, the single end amp sounded thinner with much less bass. After a few minutes of listening, it sounds moore full, almost as good as the PP amp. Is it just me getting used to the sound?
"The magnet wire used to come from Radio Shack. In keeping with their policy of figuring out what the best products are and discontinuing them they no longer have it." - Max Robinson
Old 10th March 2012, 04:09 PM   #2
CopperTop is offline CopperTop  United Kingdom
I'm pretty sure that I get used to the sound of my speakers. If I swap to a different type, I hear it for a few minutes of listening, then quickly get used to it.
I also have the opposite problem of hearing differences from one occasion to the next, when the equipment has not changed at all. (nor the temperature, humidity etc. as far as I can tell).
Old 10th March 2012, 04:30 PM   #3
Alexontherocks is offline Alexontherocks  Italy
well it is only logical to assume that if you actually believe there is a difference, the amplifier is not undergoing burning in and no other factors ar influencing the amp's funciotning then it stands to reason you are adapting to the amplifier's different sound.
Even a mindset can alter perception. Maybe you "want" for the amplifier to be a perfect substitute until the old amp is functioning again? There is a psychology of perception which is as interesting as building amps themselves.
Old 10th March 2012, 06:36 PM   #4
wicked1 is offline wicked1  United States
wicked1's Avatar
I'd say yes, you're getting used to it. I have a single ended 300b amp upstairs. A PP (sca35 clone) downstairs. Both are good sounding.
but, every time I switch amps, I think the other one sounds better.. until I get used to it.
Old 10th March 2012, 06:44 PM   #5
tomchr is offline tomchr  Canada
tomchr's Avatar
Psychoacoustics is a funny thing.
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 10th March 2012, 07:53 PM   #6
M Gregg is offline M Gregg  England
I think,
You have to take into account the warm up of components and tubes. My SE amp sounds different after a few minutes. I also think that the SE amp OP tubes run hotter than PP and take longer to reach temp.
The normal effect is for it to sound thin and lacking in the bass for a few minutes. You could prove this easily. Keep the amp on, on load for half an hour before you listen. However yes you do get used to sound, eg listen to the car stereo after the HIFI, sounds like it is faulty and after about 3 mins it sounds OK.
M. Gregg
Did I get used to my amp's sound?Hide this!Advertise here!
My New amp's jleaman Solid State 21 21st December 2006 06:03 PM
Just some picture's of my amp's lykkedk Everything Else 0 11th March 2006 12:16 PM
amp's inner wiring rnzr Solid State 2 15th April 2005 01:51 PM
What limits an amp's output? BAM Chip Amps 9 14th July 2004 08:12 PM
2 AMP's????? Ryancowe Car Audio 5 26th May 2004 04:39 PM
