#21 | |
diyAudio Senior Member
Frank |
#22 |
Hi Frank,
well the circuit is virtually built, I didn't want to subject the 3a5's to this voltage incase they went lunar......... The 170v at b+ with no load worried me, given that the max for the 3a5's is 135v, so I thought I'd ask before having to fork out for new tubes.... Do you think the tubes will be okay if i Just test the rail with them connected? Incidentally I did use a light bulb across B+, it was a 60w 240v type, the voltage at B+ fell to 21 volts or so...????? thanks Raja |
#23 |
You may be overloading your PS. Be careful. Frank forgot to mention the wattage of the light bulb but you should know that a 60W light bulb is not equivalent to a 470kohm resistor.
#24 |
Don't worry won't be using the bulb again
Thanks Raja |
#25 | ||
Or use a linear 1K pot of say 3-5 Watt and connect the wiper to the output. Set it to 1K, let the circuit warm up, adjust for 110V...switch of and measure the resistance across the pot. Replace the pot with the closest matching R. Quote:
Too lazy to do the maths...hey, it's Sunday. Cheers,
Frank |
| Using mains transformer as output transformer | Elias | Tubes / Valves | 176 | 11th March 2013 09:35 PM |
| Modulation transformer for a driver transformer? | ironradio | Tubes / Valves | 6 | 28th December 2008 05:05 PM |
| filament transformer vs plate transformer | contaxchen | Tubes / Valves | 10 | 14th January 2005 10:43 AM |
| toroid Transformer as power Transformer for tube | tone | Tubes / Valves | 7 | 11th February 2003 08:57 AM |
| toroid Transformer as output Transformer for tube preamp? | tone | Tubes / Valves | 15 | 2nd February 2003 04:36 AM |
