Why this huge cap is so light?
Old 8th March 2012, 01:48 AM   #1
siliconray is offline siliconray  China
Default Why this huge cap is so light?
Got another type of huge cap, even bigger than this one I posted here a few days before. Oddly the blue giant is very light. It's a USA made cap, marked "CAPACITOR TECHNOLOGY", Does any one know about this brand?
www.siliconray.com High Quality Audio Enclosures, Amp Kits, Amplifiers, PCB Fab Services
Chat with me
Old 8th March 2012, 05:53 AM   #2
Enzo is offline Enzo  United States
With a 1984 date code, maybe its electrolyte has evaporated away.
Old 8th March 2012, 06:04 AM   #3
riccoryder is offline riccoryder
Maybe it's like the old NiCd D batteries that had an AA sized cell inside.
Old 8th March 2012, 06:28 AM   #4
I have both the same thoughts before. But it works very well. It didn't explode under 420V DC. My tube amp is totally hum free when use this as power bypass. The speaker is still singing after 20 seconds of turnning of the power switch. Just courious why it's so light.
Chat with me
Old 8th March 2012, 06:56 AM   #5
wrenchone is offline wrenchone  United States
wrenchone's Avatar
The Capacitor Technology computer grade capacitors were always suspiciously light compared to competing brands (Sprague. Mepco, UCC, etc.) of similar pedigree. I can't explain it. Maybe I should succumb to curiosity and peel one open (I have a few) to see what's going on, but I've never felt sufficiently motivated, and anyway, I don't think they're around any more.
Old 8th March 2012, 01:25 PM   #6
Tom Bavis is offline Tom Bavis
Tom Bavis's Avatar
As I recall, Cap Tech did not use the typical potting compound in their electrolytics - instead, there was a "spike" in the bottom of the can that kept the capacitor winding in position and conducted heat to the can. Advantage they gave was that these caps could be mounted in any position - others recommended only "terminals up". Reason was that at end of life, cap heating could cause the potting compound to melt and plug the vent (next to terminals). If cap overheats with blocked vent, the can could explode... Philips made similar caps, but crimped the can - odd to see the "dented" cans, but they also work fine.
Why this huge cap is so light?Hide this!Advertise here!
cap for adding offset before adc - but which cap in signal path?? thesoundlab Parts 3 31st March 2011 03:50 AM
Huge cap inside battery charger jitter Everything Else 2 10th November 2010 03:06 PM
Polar electro with bypass cap to replace nonpolar as coupling cap? at77 Parts 0 12th January 2010 02:05 AM
Help Need huge audio cap Rockmore Parts 7 7th January 2010 09:02 PM
.22uf cap in place of .25uf coupling cap, OK? bbaker6212 Tubes / Valves 5 15th July 2002 09:08 PM
Copyright ©1999-2017 diyAudio
