Capacitor WVDC. is higher really better? - diyAudio
Old 8th March 2012, 01:44 AM   #1
bichela is offline bichela  United States
bichela's Avatar
Default Capacitor WVDC. is higher really better?
I am going to be doing three different amp projects. one is a recap of an older tube amp in a Sony TC-200 (first version), recap a working mono Philips 4 track unit and the third is my 6BM8 Push Pull amp (Fire and Ice).
I need to buy caps for all three. but I only want to deal with one set. the caps I was told it is fine to go with higher than the rated voltages. in the TC-200 it shows that for the power supply filter caps are 3 100uf 180WVDC whereas in my tube amp (fire and ice) caps are needed at 300VDC ( 25uf, 25uf and 40uf))
Here is my question. is it wise to use higher WVDC caps in a circuit? One guy says no as the electrolytic won't be stable. Another says "Not a problem". I want to order the needed caps for the projects in larger quantities. Oh yeah, in my philips tube reel amp they are 35uf, 35uf and 50uf at 350WVDC. therefore I was looking to getting 400-600WVDC instead of having lots of voltage versions.
Old 8th March 2012, 02:10 AM   #2
Chris Hornbeck's Avatar
It's both wise and recommended. Be conservative (about voltage and temperature ratings).
All good fortune,
Chris
Old 8th March 2012, 03:59 AM   #3
kevinkr's Avatar
Modern electrolytics are much more stable than those of yore and operating a high voltage cap on a significantly lower voltage should not cause an appreciable reduction in capacitance.
As long as proper voltage derating guidelines are followed the real cap killer is temperature. 105C types will generally live a lot longer at any given operating temperature than a device rated for 85C. (And a 10C reduction in cap temperature doubles life - so keep as cool as possible.)
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 8th March 2012, 05:49 AM   #4
bichela's Avatar
And what are these guidelines exactly? As for "keeping cool" the Phillips is a plastic heat box I don't think I can do much about that. Sony has a good air flow as would my amp design. Yes, I am speccing 105c parts
Old 8th March 2012, 06:13 AM   #5
kevinkr's Avatar
The manufacturer will generally provide derating guidelines in the data sheet or an app note - if not I would not exceed 80% for an aluminum electrolytic.
Old 8th March 2012, 06:21 AM   #6
bichela's Avatar
Okay so a 400wvdc cap at 160 would be okay as using the 70%. Or 280 means 120vdc would be the "floor"
Old 8th March 2012, 08:18 AM   #7
Cornell Dubilier say 50% voltage derating is common in space and military applications because it extends capacitor life. So obviously no harm in using a higher rated cap at lower voltages.
The only time to worry is if the ripple current is very high and a higher voltage cap is replaced where a same size but lower voltage cap has been used. The higher voltage rated cap will have lower capacitance and probably lower ripple current rating. This isn't applicable in your situation.
I read some paper by a chemist that using an electrolytic at lower voltages for a long time, essentially created a new rating for that cap. The cap would need to be reformed if it were to be reused at higher voltages.
Old 8th March 2012, 08:52 AM   #8
M Gregg is offline M Gregg  England
Just a thought,
If your caps are close to working voltage and you have a heater supply fail or your fuses are after the caps on the HT rail. Then the increase in the B+ with no load could exceed the WV of the caps creating a capacitor blow out. I don't think you should ever have less than B+ off load working voltage.
M. Gregg
Old 8th March 2012, 09:30 AM   #9
bayermar's Avatar
M. Gregg
+1
Especially if you cannot entirely rule out that you will create off-load conditions in case of a failure (and in most cases you cannot rule this out).
Easier to buy a higher voltage cap (or use them in series) than to remove all that gooey junk in your precious amp after a blow-up.
Martin
Old 8th March 2012, 10:07 AM   #10
In the first post he says the highest value cap to be replaced is now 350WVDC. He plans to get 400WVDC caps. So isn't he covering his *** pretty good?
SPL gets higher? frank2627 Full Range 6 1st June 2011 06:31 AM
WTB: 10,000uf or higher 71V or higher caps, max 30mmD KevinLee Swap Meet 1 10th December 2009 01:39 AM
Is it true that the higher the BL of a subwoofer, the higher its lowest playable... 454Casull Subwoofers 16 19th March 2004 05:28 PM
Flying higher and higher with the Doede Dac Lucas_G Digital Source 139 27th February 2004 07:40 AM
Super-power amps - higher current better than higher voltage Circlotron Solid State 34 28th June 2002 05:01 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
