Hello,
I have a couple of 6CG7's and I wonder if anyone can present a line stage circuit where these tubes are used. Last edited by GoranB; 7th March 2012 at 05:19 PM. |
#2 |
#3 | |
#4 |
Also a couple of schematics for line preamps on Patrick Turners Web site. See link below. miscellaneous-schematics2 {Note page down to pre-amp section right at the bottom of the web page} Cheers, Colin |
#5 |
They are basically a 6SN7 in a small 9 pin bottle. Any of the multitude of designs out there for 6SN7s will work.
Au rutti wop-bop-a-loom-bop-a-boom-bam-boom - Richard Penniman |
#6 |
Thank you all!
Im reading about Aikido at the moment, and i have a question. If i understood well, I can use different tubes for input to achieve more or less gain without changeing passive elements? I know i should change the filament voltage depending on type of a particular tube, but the catode/anode ressistors remains same? http://www.tubecad.com/Product_PDFs/...ereo_Rev_C.pdf |
#7 |
Ignore my previous post please. I allready have the answer.
| buffer line stage schematic | yero | Tubes / Valves | 8 | 1st May 2011 09:42 AM |
| Line stage with 12AU7 and 6CG7 anyone? | sbelyo | Tubes / Valves | 6 | 11th February 2011 12:55 PM |
| 6DJ8 tube schematic as balanced line stage? | gaborbela | Tubes / Valves | 1 | 18th March 2010 09:26 AM |
| Stage Line PMX-700DSP Schematic Wanted | Kinger | Instruments and Amps | 0 | 24th August 2009 02:05 PM |
| balanced line stage schematic needed | jogas | Tubes / Valves | 3 | 11th September 2005 08:57 PM |
