Hello, did anybody try to built a HV power supply with serial connected chokes? I think to connect e.g. 10H + 100mH + 1mH in series, from a theoretical point this should improve high frequency characteristics. Because the (high) shunt capacitance of the big 10H is in series with the smaller shunt capacitance of the smaller chokes. Anybody tried?
#2 |
It may make sense if you were able to identify the level of high frequency content you have at the rectifier end, and the impedances (versus frequency) of the shunt filtering you have before and after, and of the level of high frequency content you need to keep below on the other end (or somewhere else in your circuit) - this last point going to why you want to focus on HF (rather than VHF or UHF).
#3 |
Have a look in the Morgan Jones book - If I remember it correctly, he describes something using different choke filters in series to expand the usable range of PS filtering up to high frequencies...
I'll see if I find it in my copy and post the main idea... Greetings, Andreas |
#4 |
I'd be guessing that the high-frequency impedance of the main choke can be checked with a sig gen and reading the current via the voltage across a sense resisor, and reading the sig gen voltage - that may indicate better where the main choke starts to lose its 'L' impedance characteristic. Which would then be a guide to what extra series L is needed - but that is effectively all about maintaining a high impedance (rather than the L component) as the frequency increases. Ie. the opposite of parallel capacitors with maintained low impedance as frequency increases. You may also need to dampen the main choke if you're worried about passing high frequencies through it.
#5 |
Scan the archives for my posts on "hash" filters. LC sections made from high current RF chokes and mica or NPO ceramic caps. suppress trash extending up into RF before it can sneak into the rail via the effective capacitance of a large inductor.
Eli D. |
| HV paper in oli caps and Peerless chokes | Mother of PEARL | Swap Meet | 4 | 26th October 2010 02:50 AM |
| power supply chokes for solid state? | dorkus | Solid State | 36 | 1st December 2009 12:56 AM |
| Help with HV DC Power Supply | furly | Planars & Exotics | 3 | 2nd February 2006 12:04 PM |
| Parallelling power supply chokes??? | Klimon | Tubes / Valves | 4 | 18th May 2005 07:46 PM |
| HV power supply repair | smoking-amp | Tubes / Valves | 1 | 17th February 2005 02:42 AM |
