Op Amp
Op Amp
Old 4th March 2012, 11:50 PM   #1
dirkwright is offline dirkwright  United States
dirkwright's Avatar
Default Op Amp
I was fooling around with Tina over the last couple of days after downloading some spice models for vacuum tubes. I got the 12AX7 and 12AU7. So, I came up with a little op amp. Distortion is 0.0003% @ 1kHz, 1Vp-p input. I'm sure this is probably already old, but playing around with Tina is fun.
Old 5th March 2012, 12:47 AM   #2
Eli Duttman is offline Eli Duttman  United States
WAY too much "sand". Google Philbrick opamp.
Eli D.
Old 5th March 2012, 01:50 AM   #3
dirkwright's Avatar
Thanks!
I think mine is better...
Old 5th March 2012, 05:05 AM   #4
stratus46 is offline stratus46  United States
Originally Posted by dirkwright View Post
Thanks!
Except yours is AC coupled and cannot operate to DC like the Philbrick.
G
Old 5th March 2012, 01:33 PM   #5
dirkwright's Avatar
G
I was joking! Horses for courses.
But yes, of course. He had to have DC response for his application. We don't need that. Response down to 1Hz is fine in my opinion.
Old 5th March 2012, 03:47 PM   #6
dirkwright's Avatar
I tried replacing the CRD's with a 12AX7 CCS but the performance was worse. I'm not aware of being able to make a current mirror with vacuum tubes.
Old 5th March 2012, 04:50 PM   #7
artosalo is offline artosalo  Finland
artosalo's Avatar
This has small gain but is dc-coupled.
Old 5th March 2012, 07:35 PM   #8
dirkwright's Avatar
Yeah, he's throwing away gain with the voltage divider between the differential amp and the output stage. I haven't modeled this one yet. Thanks!
Old 5th March 2012, 08:23 PM   #9
SemperFi is offline SemperFi  Wake Island
Mirror mirror...
R5 and R13 could (should?) be CCS, got lazy drawing this up
Old 5th March 2012, 08:56 PM   #10
artosalo's Avatar
This was simplest way to level the output to zero DC-volts ( when input is zero too).
Op AmpHide this!Advertise here!
2x Gain pure op-amp headphone amp idea Dxvideo Headphone Systems 31 6th August 2017 06:09 PM
op-amp + op-amp buffer combinations eccdbb Chip Amps 2 22nd July 2011 05:13 AM
Poor power output, op amp based headphone amp. dannybeckett Solid State 13 27th September 2010 09:31 PM
Who has tried a current boosted op-amp (with a transistor) as a chip-amp buffer? sardonx Chip Amps 18 19th March 2005 01:23 PM
New OP-AMP for Music Man HD-130 bass amp Kevin McCready Solid State 0 8th September 2002 12:35 AM
