#21 |
Hi formula 22
I don't made tis amp because I prefer BJTs as output devices, lateral MOSFETs are very difficult to obtain and there are a lot of fakes, vertical MOSFETs like IRFP240/9240 are designed for switching applications. I'm building my own 25W class A hybrid, see in the forum for schematics. Best regards Johann |
#22 | |
Can you recommend a good quality one preamp with tube/valve ECC82 or PCC88 (schematic or project). Thank you for your cooperation. ![]() Cheers!
#23 | |
SRPP-Vorverstärker You can see my hybrid here 25W Class A Hybrid Amp
I do not suffer from insanity, I enjoy every minute of it. -Edgar Allan Poe I hate idiots, that's why my house has no mirrors. -Just me ? |
#24 |
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
| Hybrid amplifier with PCC88 + LM1875 | formula 22 | Chip Amps | 0 | 7th February 2012 05:37 AM |
| 200 Watt Lateral Mosfet Amplifier and irfp240/9240 | tino96 | Solid State | 39 | 6th April 2004 12:06 AM |
