ARC D-75A Regulator tube
Old 3rd March 2012, 06:30 PM   #1
john65b is offline john65b  United States
john65b's Avatar
Default ARC D-75A Regulator tube
Hey all, I have a D-75A amp, and the regulator tube (6550) seems to have flaked out...I have a 6L6GC that I am thinking of using, as the D-75 amp schematic has a 6l6GC instead of the 6550 for the regulator tube.
Looking at both schematics for the D-75 and D-75A, they both show the same 575v on the plates of the regulator tube, but the max plate voltage is 500v for the 6l6GC...
Any issues in using it as the regulator tube? I don;t think the current through this regulator tube is very high...
I Speak Spanish to God, Italian to Women, French to Men, and German to My Horse. Charles V
Old 3rd March 2012, 06:45 PM   #2
HollowState is offline HollowState  United States
HollowState's Avatar
While the 6550 is an all around better tube for the most partr, a 6L6GC will work ok. Remember that the cathode will be elevated and there will be a lot less then 500 volts across the tube. And lots of old style tube regulated power supplies like those of Lambda, Fluke and even Kepco used 6L6's as series pass tubes without issue.
1944: 18 year olds storm the beach of Normandy into almost certain death.
2017: 18 year olds need a safe place because words hurt their feelings.
Old 3rd March 2012, 06:58 PM   #3
john65b's Avatar
Good deal...thanks
I also have a metal tube RCA 6L6 too....not a 6L6gc, but could it also work as a regulator tube? Would one be preferred over the other in this amp?
Old 3rd March 2012, 07:08 PM   #4
I would stick with the newer glass 6L6GC just on general principal.
Old 3rd March 2012, 07:13 PM   #5
john65b's Avatar
Alright then, thanks again.
ARC D-75A Regulator tubeHide this!Advertise here!
12V to 30-32V 1.5-1.75A ? hlmasterchief93 Construction Tips 2 16th October 2011 04:15 AM
need data on ARC 4700 and ARC 4800 woody Solid State 2 14th August 2011 05:08 PM
ARC LS25 mkII tube change GeneJazz Analog Line Level 6 18th October 2010 05:09 PM
Copyright ©1999-2017 diyAudio
