Phase splitter into push pull front end - possible? - diyAudio
Old 2nd March 2012, 07:35 PM   #1
JZatopa is offline JZatopa  United States
Default Phase splitter into push pull front end - possible?
So I was looking at a PP schematic and I got to thinking. Could your preamp stage be push pull? I don't see why but to do so you would need a phase spliter to be the first stage of your amp. Now that is something I am not sure is possible. So can you have a phase spliter be the first part of an amplifier?
Old 2nd March 2012, 08:06 PM   #2
DF96 is offline DF96  England
You could, but it creates complication with little or no obvious advantage.
Old 2nd March 2012, 08:15 PM   #3
Stop pulling his leg DF. We all know it cant be done, no way.
Old 2nd March 2012, 08:30 PM   #4
Palustris's Avatar
A phase splitter can certainly be the first stage in an amplifier. Two common topologies are a long tail pair with one triode driven by the input and an CCS in the tail ensuring equal output from the two triodes or an input transformer that splits the phase.
Old 2nd March 2012, 11:22 PM   #5
aardvarkash10's Avatar
exactly the topology used in baby huey...
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile,
Old 3rd March 2012, 12:39 AM   #6
Tubelab_com's Avatar
I have built a power amp where all three stages are LTP's with a CCS in the tails of each stage including the output stage. So which stage or stages are the phase splitter. The amp sounds quite nice BTW.
It is possible to make a preamp with all LTP's too, and you can wire your phono cartridge differentially so that everything from the vinyl to the speaker is balanced. I started down this path years ago but haven't finished it yet. Some day......
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 3rd March 2012, 08:01 AM   #7
No its not!
Old 3rd March 2012, 07:31 PM   #8
popilin is offline popilin  Argentina
popilin's Avatar
Yes, it is possible and more simple, see the VDV-PR20HE by Menno Van Der Veen as an example.
UL40-S2-Mod
Best Regards
Johann
Old 3rd March 2012, 09:54 PM   #9
Yvesm is offline Yvesm  France
Yvesm's Avatar
All serious amplifiers should be designed that "symmetric" way from the front end:
-Better S/N ratio
-Less distortion
-Larger signal headroom, can eventually reaches twice the B+
Well, tube count is doubled . . .
Yves.
Old 3rd March 2012, 11:03 PM   #10
It is possible.......No its not!
When someone tells me that something is not possible, I usually just go and do it. But when someone tells me that something that I (and others) have already done, With no proof or explanation.....I just ignore them....and their future posts.
-Better S/N ratio
This concept has been thouroughly explored already. Google "downward dynamic range". Once you have achieved extreme amounts of power you can make the loud stuff plenty loud. To further improve the system dynamic range you must make the quiet stuff quieter. This means chasing all the hum and noise out of the system. Differential circuitry has better PSRR and hum immunity. Opamps are all designed this way.
Allen Wright of Vacuum State Electronics published several preamp and power amp designs that are fully differential from the phono cartridge to the OPT. Some of the designs are 14 years old. It can and has been done.
Any high-end 6BM8 push pull tube amp schematic ? gaetan8888 Tubes / Valves 13 24th October 2010 11:26 PM
Phase inverting one half of a push-pull parrallel channel before recombining? Test Electrix Power Supplies 3 23rd March 2009 08:04 PM
Please Explain difference Mono vs Push Pull vs Single End etc hdlcx2 Tubes / Valves 11 3rd August 2008 03:27 AM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 4th November 2005 12:25 AM
Copyright 1999-2017 diyAudio
