Old 2nd March 2012, 03:51 PM   #1
Default Question on push-pull OT LEads
OK, so this might be a dumb question but why does reversing the primary leads on a push pull output transformer drive an amp into parasitic oscillation? Looking at the basic transformer wiring schematic it appears be symmetrical? Is there a standard to know which lead has to go to the input side and which lead has to go to the side with negative feedback applied? thanks.
Old 2nd March 2012, 04:46 PM   #2
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Does the amplifier have negative feedforward from any secondary of the transformer? IF any, reverting input get it to positive FB, converting the amp in an oscillator.
LW1DSE
Old 2nd March 2012, 07:12 PM   #3
DF96 is offline DF96  England
This is not parasitic oscillation, but loop oscillation. Parasitic oscillation occurs within a single stage, typically the output although it could be an earlier stage. It is caused by parasitic components e.g. stray capacitance, lead inductance.
Old 3rd March 2012, 05:40 AM   #4
AJT is offline AJT  Philippines
AJT's Avatar
secondary phasing is important, if you get it wrong, there will be oscillation, you get it right and you get the nfb working correctly.....it is a 50-50 chance you will get it right the first time....
Push - Pull improvement question ? goldyrathore Multi-Way 20 1st January 2011 03:34 PM
A question about Push-pull class-a mutter Pass Labs 8 17th July 2010 07:04 PM
Push-Pull question roomi Power Supplies 5 26th December 2008 10:53 PM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 3rd November 2005 11:25 PM
Double push-pull versus single push-pull jraraujo Tubes / Valves 19 19th October 2002 12:23 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
