Old 2nd March 2012, 09:18 AM   #1
Default measuring dc offset in OTL headphone amp
I've not managed to find a consensus on this, perhaps someone can chime in: is it more relevant (as in: will the amp damage my headphones longterm) to measure the dc offset with or without a headphone load connected?
Example: my OTL tube amp measures around a meandering few +/- mV unloaded, sometimes hitting 10-30mV and, with my DMM set to record min/max/avg over ten minutes or so, a peak of -300mV, although this was definitely a spike, it didn't slowly climb to, or fall from this value.
With a 600ohm headphone load connected, it's typically <1mV, peak of 5mV, per channel.
All measurements taken after the amp has warmed up for over a minute or two.
Which is the figure to be more confident with??
Old 2nd March 2012, 09:47 AM   #2
Doz is offline Doz  United Kingdom
Doz's Avatar
Do you not have an output coupling cap?
"To err is human.. to make a real balls-up requires a computer"
Old 2nd March 2012, 09:50 AM   #3
yep - 91uF film caps
Old 2nd March 2012, 07:49 PM   #4
Doz's Avatar
Then you shouldn't have a DC offset, unless your cap is goosed.
Sent from my iPad using Tapatalk
Old 2nd March 2012, 08:10 PM   #5
thanks
HEADPHONE AMP TUBES NOS OTL claudiomas Swap Meet 0 21st August 2011 04:41 PM
DC Offset on Class A headphone amp. Dxvideo Headphone Systems 44 21st July 2007 08:35 AM
How much DC offset allowed in headphone amp? jwb Headphone Systems 2 5th August 2003 11:15 AM
OTL 6L6 headphone amp-idea+need help trespasser_guy Headphone Systems 16 25th March 2003 01:26 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
