Old 1st March 2012, 05:37 PM   #1
Calamaro's Avatar
Default grundig tk45
I'm starting to learn something about tubes. Planning to build some very basic amp in the next future. I can have for 40 euros this old Grundig reel to reel: do you think that I could recicle the internal amplifier or some useful parts?
TK45 R-Player Grundig Radio-Vertrieb, RVF, Radiowerke, build
http://www.thaigramophone.com/defaul...d=65&qid=22504
Old 1st March 2012, 06:06 PM   #2
GloBug is offline GloBug  Canada
Banned
Absolutely.
It even appears to be Stereo. If not there is still some decent tubes in there. ie: 12AX7s etc.
Have fun.
Old 5th March 2012, 05:22 PM   #3
If the ELL80 output tube is ok, you might have a bargain. If not; you'd better forget about it.
Best regards!
Old 5th March 2012, 05:29 PM   #4
Calamaro's Avatar
What about output transformers? Are they useful for same little first project (i.e. with pcl86 or even el34)?
Old 5th March 2012, 05:32 PM   #5
Perhaps they are. But € 40 for just a power tranny plus two output trannys in the 2-3 watts region seems a little bit too much ;-).
And forget about EL34's with theses transformers...
Best regards!
Old 5th March 2012, 05:37 PM   #6
rajucc is offline rajucc  India
Good output tranny cost about 600 euro
Sent from my LG-P500 using Tapatalk
Old 5th March 2012, 05:45 PM   #7
Calamaro's Avatar
I believe that three new transformers cost more than 40 euros.
If you believe that these output transformers can be used with two pcl86 maybe I could take them to try the simple "Insulto finale" amp.
Old 5th March 2012, 06:01 PM   #8
DF96 is offline DF96  England
One ELL80 is two EL95 in one envelope. An EL95 is quite a low power output valve, so a transformer designed for it might not work too well with a PCL86.
Old 5th March 2012, 06:07 PM   #9
Calamaro's Avatar
Ok thanks.
Old 5th March 2012, 06:15 PM   #10
You don't really think that the output trannys in this TK 45 are good ones, do you?
Best regards!
Grundig cd7500 bosetuno Digital Source 5 15th May 2011 01:55 PM
Grundig 3028 HELP Omegaman Tubes / Valves 7 28th December 2010 05:57 PM
Old Grundig Fullrange fun Pano Full Range 13 20th January 2009 11:16 PM
Grundig A-9000 broken :( mat_one Solid State 9 26th November 2008 02:01 PM
Grundig CD303, anyone know it? tubenut Digital Source 0 30th May 2008 06:33 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
