Help: Western Electric 418A tubes wire in triode ? - diyAudio
Old 1st March 2012, 01:17 AM   #1
Default Help: Western Electric 418A tubes wire in triode ?
Could someone tell me how to wire the Western Electric 418A in triode ?
I want to use this tube for a preamp.
Old 1st March 2012, 01:38 AM   #2
HollowState's Avatar
Simply connect pin 5 (screen) to pin 2 (plate). You could use a small value resistor of about 100 ohms to do this, but It's probably not necessary.
1944: 18 year olds storm the beach of Normandy into almost certain death.
2017: 18 year olds need a safe place because words hurt their feelings.
Old 1st March 2012, 01:44 AM   #3
Thanks for the help.
Could you tell me what is the appropriate primary impedance of output transformer for this tube ?
Old 2nd March 2012, 01:19 AM   #4
I want to use output transformers with this tube.
Can someone tell me what is the appropriate primary impedance?
Old 2nd March 2012, 02:20 AM   #5
In order to provide a proper answer, more information is needed including operating points and triode plate curves. I doubt very much if triode curves for this tube exist. While I was in the surplus tube business for years, and have an extensive tube data library, I've never seen WE triode curves for any of their pentodes.
Further complicating matters is the fact that this is not a popular WE tube and I suspect few builders have ever worked with it. Also, most all WE tubes are unique unto themselves and have no close generic counterparts to compare to.
Given all of this and the knowledge that triode connecting most any pentode lowers the plate impedance, if I had a gun to my head, I would guess a load impedance of somewhere between 2500 to 5000 ohms would be close. But it's only a guess.
Old 2nd March 2012, 02:41 AM   #6
astouffer's Avatar
I built an amp with 429A pentodes and found them to be hit or miss in how well they work. One tube just starts to work well when the grid is sitting at 0 volts The others seem weak overall and don't bias close to what the specs say. The bad tube works better when the heater is run a few volts higher but it probably has a bad vacuum. I tried "cooking" it at higher currents but it always settled back.
Old 2nd March 2012, 02:54 AM   #7
smoking-amp's Avatar
Looking at the datasheet for the 418A, can calculate the triode Mu off the bottom page 3 graph of plate current versus grid voltage as around 30 to 35 approx. (depending on current op.)
http://www.scottbecker.net/tube/sheets/084/4/418A.pdf
Then assuming the triode gm is the same as the pentode gm at any given op. current, one should be able to calc. the triode plate Rp from Mu = gm * Rp.
So at 50 mA, 33 = .0265 * 1245 => 1245 Ohms Rp, an estimate anyway.
Lower current will decrease gm and raise Rp as the Ip^.5 power roughly, or derive from the graphs.
Old 2nd March 2012, 03:43 AM   #8
Thanks guys for the information.
Western Electric 396A tubes Andy Bartha Swap Meet 0 31st March 2011 08:53 PM
Western Electric 374A john Tubes / Valves 4 21st December 2005 03:17 PM
Western electric VT1 tubes battradio Tubes / Valves 7 19th January 2004 03:29 AM
Western Electric PassFan Tubes / Valves 0 26th April 2003 01:09 PM
Copyright 1999-2017 diyAudio
