Old 29th February 2012, 09:23 PM   #1
Obrien is offline Obrien  United States
Default Scott 355 Tuner-Preamp
Does anyone have a voltage chart or resistance chart for the Scott 355 Tuner-Preamp?
Old 29th February 2012, 09:47 PM   #2
HollowState's Avatar
Here's the schematic. It has voltages marked on it. A little hard to read, but enlarging it 200% helps.
http://hhscott.com/pdf/355.pdf
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 29th February 2012, 11:32 PM   #3
Default voltages for Scott 355
Thanks. I was trying to avoid making a voltage chart by hand from that schematic (I agree, it's hard to read), but I think that is the best option. Thanks for the reply.
Scott 350B Tuner; Bridge Rectifier UncleArt Tubes / Valves 3 18th July 2010 02:16 PM
?? xmer specs for Scott LC 21 or 130 Preamp for rewind... crispycircuit Tubes / Valves 0 9th January 2008 10:01 PM
Pioneer DV-355 Audiohifi Digital Source 0 11th December 2005 10:27 AM
Suggest a preamp for cd/tuner BeerCan Tubes / Valves 2 16th June 2005 12:14 PM
Pioneer DV-355 sparkle Digital Source 0 24th September 2004 07:17 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
