Old 29th February 2012, 06:09 PM   #1
Globulator's Avatar
Default Max anode voltage and srpp/aikido amps
I'm successfully running a 6n2p SRPP across a 400V rail despite it's max anode voltage being 300V, and would ideally run one across 500V or 750V but I'm a bit worried about them arcing inside (or on the base).
The 6n6p has a max anode rating of 450V so perhaps that would be better for 500V, although 750V may be pushing it a bit.
Has anyone experience with these issues? The top tube heater voltage would have to be gently fixed with a high resistance at some mid-value too.
Is there a favourite noval tube for these voltages or does everyone go octal at this point?
How does anode voltage swing to twice HT voltage? cricha5 Tubes / Valves 16 20th January 2011 01:51 PM
max voltage and amps for ta2020 amp frankslan Class D 1 30th December 2010 09:44 PM
Calculating max Anode Voltage b139b Tubes / Valves 0 31st January 2008 08:11 PM
Replacing cathode resistors of Aikido 1st stage (or other SRPP circuit) with chokes snoopyma Tubes / Valves 1 31st July 2006 05:21 PM
Anode Resistors on PPP Amps gingertube Tubes / Valves 9 21st February 2005 03:28 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
